Ana içeriğe geç
Yuneec Typhoon H Landing Gear Replacement
Neye ihtiyacın var
  1. Yuneec Typhoon H Landing Gear  Replacement, Landing Gear: adım 1, 2 resimden 1. Yuneec Typhoon H Landing Gear  Replacement, Landing Gear: adım 1, 2 resimden 2.
    • Lift all drone arms up so you can access the landing gear easily.
  2. Yuneec Typhoon H Landing Gear  Replacement: adım 2, 3 resimden 1. Yuneec Typhoon H Landing Gear  Replacement: adım 2, 3 resimden 2. Yuneec Typhoon H Landing Gear  Replacement: adım 2, 3 resimden 3.
    • Unscrew the 16.9 mm screw at the top of the landing leg with a Phillips #00 screwdriver.
    • Make sure the screw head is not stripped in the process.
    • If stripped, the whole leg, including the internal sensors, will need to be replaced.
  3. Yuneec Typhoon H Landing Gear  Replacement: adım 3, 1 resimden 1.
    • Pull the landing leg out slowly and remove it from the device.
Sonuç
Your Yuneec Typhoon H should now be ready to fly safely again.
Bir başkası bu kılavuzu tamamladı.
Shasta Banchio
130 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team S22-G3, Maness Spring 2018 Cal Poly, Team S22-G3, Maness Spring 2018 üyesi
CPSU-MANESS-S18S22G3
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 12
Her zaman: 980
