Giriş
The landing gear of the Yuneec Typhoon H Plus is integral to beginning and ending flights. It is motorized, allowing the legs to fold up and out of the way during flight. It is possible for these legs to get damaged, or for the motor to stop working. Either of these issues will prevent proper usage of the drone. This guide will show you how to replace the landing gear of the Yuneec Typhoon H Plus. No special skills are required for this replacement.
Neye ihtiyacın var
Remove two 11 mm screws from the base of the landing gear with a 2mm hex bit.
