Ana içeriğe geç
Yuneec Typhoon H Plus Propeller Replacement
    1. Yuneec Typhoon H Plus Propeller Replacement, Propeller: adım 1, 1 resimden 1.
      • Locate the broken propeller and figure out if it is a A-propeller or B-propeller.
      • An A-propeller will have a black button in the center and an A imprinted on the propeller.
      • A B-propeller will have a white button and a B imprinted on the propeller.
      • Though the A and B propellers are different the steps to replace one are the same.
      FixBot'a Sor
      Yorum Ekle
    2. Yuneec Typhoon H Plus Propeller Replacement: adım 2, 1 resimden 1.
      • Press down on the button firmly.
      FixBot'a Sor
      Yorum Ekle
    3. Yuneec Typhoon H Plus Propeller Replacement: adım 3, 2 resimden 1. Yuneec Typhoon H Plus Propeller Replacement: adım 3, 2 resimden 2.
      • Hold the base of the propeller with your pointer finger.
      • Make sure to continue to hold the button down. Rotate the propeller counter-clockwise, holding the base steady.
      • Lift the propeller off the drone.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Brice Black
557 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S2-G1, White Winter 2020 Cal Poly, Team S2-G1, White Winter 2020 üyesi
CPSU-WHITE-W20S2G1
4 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 23
Her zaman: 439
