Ana içeriğe geç
Yuneec Typhoon H Slip Ring Yaw Motor Replacement
Neye ihtiyacın var
  1. Yuneec Typhoon H Slip Ring Yaw Motor Replacement, Slip Ring Yaw Motor: adım 1, 1 resimden 1.
    • Remove the Motor Battery Component from the Drone.
  2. Yuneec Typhoon H Slip Ring Yaw Motor Replacement: adım 2, 2 resimden 1. Yuneec Typhoon H Slip Ring Yaw Motor Replacement: adım 2, 2 resimden 2.
    • Prop the top cover of the motor piece off the Motor Battery Component. Using Phillips #00 screwdriver, unscrew the three screws (their lengths are 5.9 mm) that are in this top cover piece. This will remove the battery from the top piece.
  3. Yuneec Typhoon H Slip Ring Yaw Motor Replacement: adım 3, 1 resimden 1.
    • Grabbing the Motor Piece, remove the bottom cap of this motor piece. The cap should pop right off.
  4. Yuneec Typhoon H Slip Ring Yaw Motor Replacement: adım 4, 1 resimden 1.
    • Using the Philips #000 screwdriver, unscrew the two 5.9 mm screws and remove the retaining clip on top of the motor piece.
  5. Yuneec Typhoon H Slip Ring Yaw Motor Replacement: adım 5, 1 resimden 1.
    • Using the Phillips #1 screwdriver, remove the four 6.3 mm motor mount screws on top of the motor piece.
  6. Yuneec Typhoon H Slip Ring Yaw Motor Replacement: adım 6, 1 resimden 1.
    • Once these screws are removed, pop off the top of the motor piece.
  7. Yuneec Typhoon H Slip Ring Yaw Motor Replacement: adım 7, 2 resimden 1. Yuneec Typhoon H Slip Ring Yaw Motor Replacement: adım 7, 2 resimden 2.
    • Using the Phillips #000 screwdriver, remove the two 4.9 mm screws on the side of the plastic cover holding the wires together.
    • Once these screws are removed, press down on this plastic cover to reveal the wires. Pull the locking tabs that are on the end of this piece to completely remove this plastic cover.
  8. Yuneec Typhoon H Slip Ring Yaw Motor Replacement: adım 8, 2 resimden 1. Yuneec Typhoon H Slip Ring Yaw Motor Replacement: adım 8, 2 resimden 2.
    • Pull out the white wire connecter that is currently in the wire assembly.
  9. Yuneec Typhoon H Slip Ring Yaw Motor Replacement: adım 9, 1 resimden 1.
    Bu adımda kullanılan alet:
    Satın Al
    • Remove the white wire connector cap using the tweezers. This is for the wires that are currently in the motor piece. Do take note of the orientation and order of the wires.
  10. Yuneec Typhoon H Slip Ring Yaw Motor Replacement: adım 10, 2 resimden 1. Yuneec Typhoon H Slip Ring Yaw Motor Replacement: adım 10, 2 resimden 2.
    • Removed the damaged slip ring motor by guiding the wires through the opening in the motor piece. Use a pair of pliers to make sure the wires are pushed through the opening in the center of the motor piece.
Sonuç
To reassemble your device, follow these instructions in reverse order (This process is in the guide steps for reference).
3 farklı kişi bu kılavuzu tamamladı.
Davis Ross
321 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team S22-G3, Maness Spring 2018 Cal Poly, Team S22-G3, Maness Spring 2018 üyesi
CPSU-MANESS-S18S22G3
4 Üyeler
5 adet Kılavuz yazıldı
2 Yorum
Ive done all the above but digging out the epoxy it took almost all wire with it i couldve solderd to so what to do now its the white wire by the way the camera still stabalises and points straight just cant manually control
donkymeet - Yanıt
The White or Green wire is most likely not making connection
YuneecSkins.com -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 15
Her zaman: 1,323
