Ana içeriğe geç
ZCWA BR151 Sprayer/Pump Replacement
Neye ihtiyacın var
    1. ZCWA BR151 Sprayer/Pump Replacement, Water Tank: adım 1, 1 resimden 1.
      • Turn off the device.
      FixBot'a Sor
      Yorum Ekle
    2. ZCWA BR151 Sprayer/Pump Replacement: adım 2, 2 resimden 1. ZCWA BR151 Sprayer/Pump Replacement: adım 2, 2 resimden 2.
      • Remove the water tank by sliding the latch down with a finger and grasping the bottom of the water tank.
      • Pull it out.
      FixBot'a Sor
      Yorum Ekle
    1. ZCWA BR151 Sprayer/Pump Replacement, Sprayer/Pump: adım 3, 2 resimden 1. ZCWA BR151 Sprayer/Pump Replacement, Sprayer/Pump: adım 3, 2 resimden 2.
      • Flip the device over to access the bottom panel.
      • Remove the cloth mop covering by lifting it from the velcro on the plastic mop attachment.
      • Remove the plastic mop attachment by placing your fingers underneath and prying it up.
      FixBot'a Sor
      Yorum Ekle
    2. ZCWA BR151 Sprayer/Pump Replacement: adım 4, 1 resimden 1.
      • Remove the six 6 mm screws on the bumper guards using a Phillips #0 screwdriver.
      • Remove the bumper guards by lifting them.
      FixBot'a Sor
      Yorum Ekle
    3. ZCWA BR151 Sprayer/Pump Replacement: adım 5, 1 resimden 1.
      • Use a Phillips #1 screwdriver to remove the ten 10 mm screws from the bottom plate.
      FixBot'a Sor
      Yorum Ekle
    4. ZCWA BR151 Sprayer/Pump Replacement: adım 6, 2 resimden 1. ZCWA BR151 Sprayer/Pump Replacement: adım 6, 2 resimden 2.
      • Carefully lift the bottom panel off of the top.
      • The top and bottom panels are attached by a set of wires. They will not fully detach at this point.
      • Gently place the bottom of the device on your workspace surface, wheels down, exposing the inner workings of the device.
      FixBot'a Sor
      Yorum Ekle
    5. ZCWA BR151 Sprayer/Pump Replacement: adım 7, 1 resimden 1.
      • Though optional, we recommend separating the top and bottom panels for easy access to the sprayer/pump.
      • Pinch the wire bracket that is on the top panel while pulling the bracket away.
      • Pull the cable away from the connector in the same direction as the individual wires are running.
      • Pull evenly on the full width of the cable so that no individual wires are overly strained.
      FixBot'a Sor
      Yorum Ekle
    6. ZCWA BR151 Sprayer/Pump Replacement: adım 8, 3 resimden 1. ZCWA BR151 Sprayer/Pump Replacement: adım 8, 3 resimden 2. ZCWA BR151 Sprayer/Pump Replacement: adım 8, 3 resimden 3.
      • The sprayer is slotted in place with grooves. Slide up the sprayer by lifting it up with your fingers.
      • The sprayer/pump should loosely be free, except for wires connecting it to the motherboard.
      FixBot'a Sor
      Yorum Ekle
    7. ZCWA BR151 Sprayer/Pump Replacement: adım 9, 3 resimden 1. ZCWA BR151 Sprayer/Pump Replacement: adım 9, 3 resimden 2. ZCWA BR151 Sprayer/Pump Replacement: adım 9, 3 resimden 3.
      • Turn the device around so that the motherboard is closest to you.
      • Track the red and black wire cables from the sprayer/pump to the motherboard.
      • Remove the sprayer/pump wiring from the port on the motherboard by pinching the silver brackets and pull the wire casing away from the motherboard.
      • Remove the sprayer/pump from the vacuum.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 25
Her zaman: 1,104
