Ana içeriğe geç
ZCWA BR151 Velcro Replacement
Neye ihtiyacın var
    1. ZCWA BR151 Velcro Replacement, Velcro: adım 1, 2 resimden 1. ZCWA BR151 Velcro Replacement, Velcro: adım 1, 2 resimden 2.
      • Turn off the device.
      • Flip the device over to access the bottom panel.
      • Remove the cloth mop covering by lifting it from the velcro on the plastic mop attachment.
      • Remove the plastic mop attachment by placing your fingers underneath and prying it up.
      FixBot'a Sor
      Yorum Ekle
    2. ZCWA BR151 Velcro Replacement: adım 2, 1 resimden 1.
      • Use a Jimmy to get underneath the velcro until you are able to push it up enough to grab.
      FixBot'a Sor
      Yorum Ekle
    3. ZCWA BR151 Velcro Replacement: adım 3, 1 resimden 1.
      • Use tweezers to peel off the rest of the velcro.
      • If necessary, use the spudger to remove more of the adhesive beneath the velcro.
      FixBot'a Sor
      Yorum Ekle
      • You will need four velcro strips. Cut out two, 1-inch long strips of velcro.
      • Cut an additional two, 3-inch long strips.
      FixBot'a Sor
      Yorum Ekle
      • If your velcro strips already have an adhesive back, simply attach them to the top of the mop bracket.
      • If you are using a hot glue gun to attach your velcro, place a small section of glue where you want the velcro to go, then carefully press your piece down.
      FixBot'a Sor
      Yorum Ekle
Bitiş Çizgisi
Bir başkası bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 12
Son 30 gün: 33
Her zaman: 509
