Ana içeriğe geç
ZD-N Plus Wireless Controller Repair D-Pad Replacement
Neye ihtiyacın var
  1. ZD-N Plus Wireless Controller Repair D-Pad Replacement, Back Panel: adım 1, 1 resimden 1.
    • Remove the seven 12mm JIS #00 screws that hold the back panel in place.
    FixBot'a Sor
    Yorum Ekle
  2. ZD-N Plus Wireless Controller Repair D-Pad Replacement: adım 2, 2 resimden 1. ZD-N Plus Wireless Controller Repair D-Pad Replacement: adım 2, 2 resimden 2.
    • Lift up on the back panel of the ZD-N Plus to remove it from the rest of the controller.
    FixBot'a Sor
    Yorum Ekle
  3. ZD-N Plus Wireless Controller Repair D-Pad Replacement, Battery: adım 3, 1 resimden 1.
    • Use an opening tool to pry the battery from its original position.
    • The battery is glued on, so this may take some effort.
    FixBot'a Sor
    Yorum Ekle
  4. ZD-N Plus Wireless Controller Repair D-Pad Replacement: adım 4, 2 resimden 1. ZD-N Plus Wireless Controller Repair D-Pad Replacement: adım 4, 2 resimden 2.
    • Use an opening tool to pry the connector away from the two metallic prongs.
    • The parts are built to stay together, so this may take some effort.
    • Be careful to not warp the prongs in the process.
    FixBot'a Sor
    Yorum Ekle
  5. ZD-N Plus Wireless Controller Repair D-Pad Replacement: adım 5, 2 resimden 1. ZD-N Plus Wireless Controller Repair D-Pad Replacement: adım 5, 2 resimden 2.
    • Remove the battery from the controller.
    FixBot'a Sor
    Yorum Ekle
  6. ZD-N Plus Wireless Controller Repair D-Pad Replacement, Rumble Motor: adım 6, 2 resimden 1. ZD-N Plus Wireless Controller Repair D-Pad Replacement, Rumble Motor: adım 6, 2 resimden 2.
    • Remove the electrical connector attaching each rumble motor to the controller.
    • Lift up on the circular section of the rumble to remove it from the controller.
    FixBot'a Sor
    Yorum Ekle
  7. ZD-N Plus Wireless Controller Repair D-Pad Replacement, Motherboard: adım 7, 2 resimden 1. ZD-N Plus Wireless Controller Repair D-Pad Replacement, Motherboard: adım 7, 2 resimden 2.
    • Remove the three 1.2mm JIS #00 screws that hold the motherboard in place.
    FixBot'a Sor
    Yorum Ekle
  8. ZD-N Plus Wireless Controller Repair D-Pad Replacement: adım 8, 1 resimden 1.
    • Lift the motherboard out of the controller.
    FixBot'a Sor
    Yorum Ekle
  9. ZD-N Plus Wireless Controller Repair D-Pad Replacement, D-Pad: adım 9, 2 resimden 1. ZD-N Plus Wireless Controller Repair D-Pad Replacement, D-Pad: adım 9, 2 resimden 2.
    • Simply remove the plastic piece of the directional pad. It is not glued in so it should come out easily.
    FixBot'a Sor
    Yorum Ekle
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 20
Her zaman: 532
