Ana içeriğe geç
ZD-N Plus Wireless Controller Rumble Motor Replacement
Neye ihtiyacın var
  1. ZD-N Plus Wireless Controller Rumble Motor Replacement, Back Panel: adım 1, 1 resimden 1.
    • Remove the seven 12mm JIS #00 screws that hold the back panel in place.
  2. ZD-N Plus Wireless Controller Rumble Motor Replacement: adım 2, 2 resimden 1. ZD-N Plus Wireless Controller Rumble Motor Replacement: adım 2, 2 resimden 2.
    • Lift up on the back panel of the ZD-N Plus to remove it from the rest of the controller.
  3. ZD-N Plus Wireless Controller Rumble Motor Replacement, Battery: adım 3, 1 resimden 1.
    • Use an opening tool to pry the battery from its original position.
    • The battery is glued on, so this may take some effort.
  4. ZD-N Plus Wireless Controller Rumble Motor Replacement: adım 4, 2 resimden 1. ZD-N Plus Wireless Controller Rumble Motor Replacement: adım 4, 2 resimden 2.
    • Use an opening tool to pry the connector away from the two metallic prongs.
    • The parts are built to stay together, so this may take some effort.
    • Be careful to not warp the prongs in the process.
  5. ZD-N Plus Wireless Controller Rumble Motor Replacement: adım 5, 2 resimden 1. ZD-N Plus Wireless Controller Rumble Motor Replacement: adım 5, 2 resimden 2.
    • Remove the battery from the controller.
  6. ZD-N Plus Wireless Controller Rumble Motor Replacement, Rumble Motor: adım 6, 2 resimden 1. ZD-N Plus Wireless Controller Rumble Motor Replacement, Rumble Motor: adım 6, 2 resimden 2.
    • Remove the electrical connector attaching each rumble motor to the controller.
    • Lift up on the circular section of the rumble to remove it from the controller.
Sonuç
Jessica Newhouse
73 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 5
Her zaman: 228
