Ana içeriğe geç
ZTE Avail 2 Battery Replacement
  1. ZTE Avail 2 Battery Replacement, Battery: adım 1, 3 resimden 1. ZTE Avail 2 Battery Replacement, Battery: adım 1, 3 resimden 2. ZTE Avail 2 Battery Replacement, Battery: adım 1, 3 resimden 3.
    • Before disassembling your ZTE Avail 2, be sure it is powered off.
    • Remove the back cover using the notch at the bottom of the device.
    • Pull the back cover from the front panel gently to remove it.
  2. ZTE Avail 2 Battery Replacement: adım 2, 2 resimden 1. ZTE Avail 2 Battery Replacement: adım 2, 2 resimden 2.
    • Remove the battery by the notch in the back plate.
    • Once you have removed the battery replace it with the new one.
    • Carefully insert the new battery with the connectors aligned correctly.
    • Gently push down on the battery until it clicks into place.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Samantha Smith
309 İtibar
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 2
Son 30 gün: 8
Her zaman: 535
