Ana içeriğe geç
ZTE Avail 2 Camera Replacement
Neye ihtiyacın var
  1. ZTE Avail 2 Camera Replacement, Battery: adım 1, 3 resimden 1. ZTE Avail 2 Camera Replacement, Battery: adım 1, 3 resimden 2. ZTE Avail 2 Camera Replacement, Battery: adım 1, 3 resimden 3.
    • Before disassembling your ZTE Avail 2, be sure it is powered off.
    • Remove the back cover using the notch at the bottom of the device.
    • Pull the back cover from the front panel gently to remove it.
  2. ZTE Avail 2 Camera Replacement: adım 2, 2 resimden 1. ZTE Avail 2 Camera Replacement: adım 2, 2 resimden 2.
    • Remove the battery by the notch in the back plate.
  3. ZTE Avail 2 Camera Replacement, Camera: adım 3, 1 resimden 1.
    • Using your J00 screwdriver, unscrew each of the 8 Philips head screws from the black plate of the device.
  4. ZTE Avail 2 Camera Replacement: adım 4, 2 resimden 1. ZTE Avail 2 Camera Replacement: adım 4, 2 resimden 2.
    • Using the spudger tool, pull up from underneath the back plate and pop off the piece.
  5. ZTE Avail 2 Camera Replacement: adım 5, 2 resimden 1. ZTE Avail 2 Camera Replacement: adım 5, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Using the tweezers remove the 4 orange ribbon cables. Do this by lifting their corresponding black connectors and pulling the ribbon out.
  6. ZTE Avail 2 Camera Replacement: adım 6, 1 resimden 1.
    • On the left side you will see a cellular antenna cable wire. Remove this wire by gently pulling it off.
  7. ZTE Avail 2 Camera Replacement: adım 7, 2 resimden 1. ZTE Avail 2 Camera Replacement: adım 7, 2 resimden 2.
    • Lift up the motherboard, this may require some force because it is held on by adhesive.
    • This will allow you to access the camera and the camera mount.
  8. ZTE Avail 2 Camera Replacement: adım 8, 3 resimden 1. ZTE Avail 2 Camera Replacement: adım 8, 3 resimden 2. ZTE Avail 2 Camera Replacement: adım 8, 3 resimden 3.
    • Where you can see the front of the camera lightly push on the camera to remove the camera from its holding. The camera will come through the back.
    • Once out of the holding remove the clip holding it to the underside of the motherboard. Now the camera is removed.
    • Once the old camera is removed replace it with the new camera to complete the repair.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
haugaustin
355 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 8
Her zaman: 472
