Ana içeriğe geç
ZTE Awe Screen Replacement
Neye ihtiyacın var
  1. ZTE Awe Screen Replacement, Detach the mid frame: adım 1, 1 resimden 1.
    • Use the Phillips Head 00 screw driver to unscrew the seven 0.1mm screws from the phone's mid frame.
    FixBot'a Sor
    Yorum Ekle
  2. ZTE Awe Screen Replacement, Separate the mid frame and the digitizer: adım 2, 3 resimden 1. ZTE Awe Screen Replacement, Separate the mid frame and the digitizer: adım 2, 3 resimden 2. ZTE Awe Screen Replacement, Separate the mid frame and the digitizer: adım 2, 3 resimden 3.
    • Wedge the flat end of the spudger between the mid frame and the digitizer.
    FixBot'a Sor
    Yorum Ekle
  3. ZTE Awe Screen Replacement, Expose the motherboard: adım 3, 2 resimden 1. ZTE Awe Screen Replacement, Expose the motherboard: adım 3, 2 resimden 2.
    • Gently pry the mid frame away from the rest of the phone to expose the motherboard.
    FixBot'a Sor
    Yorum Ekle
  4. ZTE Awe Screen Replacement, Remove the ribbon wires: adım 4, 3 resimden 1. ZTE Awe Screen Replacement, Remove the ribbon wires: adım 4, 3 resimden 2. ZTE Awe Screen Replacement, Remove the ribbon wires: adım 4, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Use the tweezers to remove the four ribbon wires on the sides of the device.
    FixBot'a Sor
    Yorum Ekle
  5. ZTE Awe Screen Replacement, Orient the motherboard: adım 5, 1 resimden 1.
    • Orient the motherboard to expose the mid frame.
    FixBot'a Sor
    Yorum Ekle
  6. ZTE Awe Screen Replacement, Remove the connector: adım 6, 3 resimden 1. ZTE Awe Screen Replacement, Remove the connector: adım 6, 3 resimden 2. ZTE Awe Screen Replacement, Remove the connector: adım 6, 3 resimden 3.
    • Remove the connector to free the motherboard from the screen.
    FixBot'a Sor
    Yorum Ekle
  7. ZTE Awe Screen Replacement, Remove the cover: adım 7, 1 resimden 1.
    • Remove the back cover from the phone.
    FixBot'a Sor
    Yorum Ekle
  8. ZTE Awe Screen Replacement, Remove battery: adım 8, 1 resimden 1.
    • Pry the battery up and out of the phone.
    FixBot'a Sor
    Yorum Ekle
  9. ZTE Awe Screen Replacement: adım 9, 3 resimden 1. ZTE Awe Screen Replacement: adım 9, 3 resimden 2. ZTE Awe Screen Replacement: adım 9, 3 resimden 3.
    • Gently wedge the spudger in between the glass screen and the mid frame.
    FixBot'a Sor
    Yorum Ekle
  10. ZTE Awe Screen Replacement, Separate the motherboard from the screen: adım 10, 2 resimden 1. ZTE Awe Screen Replacement, Separate the motherboard from the screen: adım 10, 2 resimden 2.
    • Carefully pry the screen away from the motherboard.
    FixBot'a Sor
    Yorum Ekle
  11. ZTE Awe Screen Replacement, Remove the ribbons: adım 11, 3 resimden 1. ZTE Awe Screen Replacement, Remove the ribbons: adım 11, 3 resimden 2. ZTE Awe Screen Replacement, Remove the ribbons: adım 11, 3 resimden 3.
    • Be careful when removing the ribbon wires. They are delicate.
    FixBot'a Sor
    Yorum Ekle
  12. ZTE Awe Screen Replacement, Remove the remaining ribbons: adım 12, 3 resimden 1. ZTE Awe Screen Replacement, Remove the remaining ribbons: adım 12, 3 resimden 2. ZTE Awe Screen Replacement, Remove the remaining ribbons: adım 12, 3 resimden 3.
    • Remove the remaining two ribbon wires from their connectors.
    FixBot'a Sor
    Yorum Ekle
  13. ZTE Awe Screen Replacement, Expose the digitizer: adım 13, 3 resimden 1. ZTE Awe Screen Replacement, Expose the digitizer: adım 13, 3 resimden 2. ZTE Awe Screen Replacement, Expose the digitizer: adım 13, 3 resimden 3.
    • Wedge the plastic spudger between the screen and the digitizer.
    • Gently pry apart the screen from the digitizer.
    FixBot'a Sor
    Yorum Ekle
Sonuç
12 farklı kişi bu kılavuzu tamamladı.
Jennifer DeMeo
1.035 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-2, Leahy Fall 2014 USF Tampa, Team 1-2, Leahy Fall 2014 üyesi
USFT-LEAHY-F14S1G2
4 Üyeler
15 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 13
Son 30 gün: 40
Her zaman: 14,619
