Giriş
Follow this guide to remove the back case of your ZTE Axon 7 smartphone. You may need to remove or replace the back panel if it has become damaged or if you need to access the internals of your phone to work on other components.
In order perform this repair you'll need to use heat to loosen adhesive connecting the front and back of the phone. We suggest using the iOpener to warm up the edges of the phone before removing the back case. Please use caution as the iOpener can get hot. Use oven mitts if necessary. Do not overheat the iOpener as it can burst and potentially cause damage.
Before beginning this repair, but sure to turn off your phone and unplug it from the charger.
Neye ihtiyacın var
Using the SIM Tray Removal Tool, press the pin into the hole on the SIM Tray (located on the top left of the device) to eject the tray.
