Ana içeriğe geç
ZTE Blade Spark Battery Replacement
Neye ihtiyacın var
  1. ZTE Blade Spark Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Apply heat evenly on the back cover using the iOpener to soften the adhesive.
  2. ZTE Blade Spark Battery Replacement: adım 2, 2 resimden 1. ZTE Blade Spark Battery Replacement: adım 2, 2 resimden 2.
    • Carefully remove the back cover using an opening tool.
  3. ZTE Blade Spark Battery Replacement: adım 3, 1 resimden 1.
    • Use a Phillips #00 screwdriver to carefully remove all fifteen 3.0 mm screws.
    • Gently remove the SIM card tray.
  4. ZTE Blade Spark Battery Replacement: adım 4, 1 resimden 1.
    • To remove the inner white panel/cover, use a plastic opening tool to loosen from each side.
  5. ZTE Blade Spark Battery Replacement: adım 5, 1 resimden 1.
    • Set the inner white panel to the side.
  6. ZTE Blade Spark Battery Replacement: adım 6, 1 resimden 1.
    • After removing the inner white panel you should see a black panel. Use a Phillips #00 screwdriver to remove the six 4.0 mm screws.
  7. ZTE Blade Spark Battery Replacement: adım 7, 1 resimden 1.
    • Remove the black panel, revealing the battery.
  8. ZTE Blade Spark Battery Replacement: adım 8, 1 resimden 1.
    • Disconnect the tab connecting the battery to the circuit.
  9. ZTE Blade Spark Battery Replacement: adım 9, 1 resimden 1.
    • Remove the battery from the device.
  10. ZTE Blade Spark Battery Replacement: adım 10, 1 resimden 1.
    • Place battery off to the side and retrieve new battery.
Sonuç
Andrew Bliss
181 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team 1-3, Harley Spring 2023 IUPUI, Team 1-3, Harley Spring 2023 üyesi
IUPUI-HARLEY-S23S1G3
3 Üyeler
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 12
Her zaman: 148
