Ana içeriğe geç
ZTE Blade Spark Rear-Facing Camera
  1. ZTE Blade Spark Rear-Facing Camera, ZTE Blade Spark Rear-Facing Camera: adım 1, 1 resimden 1.
    • First, apply heat evenly on the back cover using a heat sack to soften the adhesive.
  2. ZTE Blade Spark Rear-Facing Camera: adım 2, 1 resimden 1.
    • Now, carefully remove the back cover.
  3. ZTE Blade Spark Rear-Facing Camera: adım 3, 1 resimden 1.
    • Once opened, Locate and remove all exposed screws using a Phillips-Head screwdriver and set them aside.
  4. ZTE Blade Spark Rear-Facing Camera: adım 4, 1 resimden 1.
    • To remove the inner white panel/cover, use a plastic opening tool to loosen from each side.
  5. ZTE Blade Spark Rear-Facing Camera: adım 5, 1 resimden 1.
    • After removing the white plastic panel, you should see a black metal battery cover.
    • To remove the metal battery cover, remove the screws from the panel using a Phillips screwdriver if you have not yet done so.
  6. ZTE Blade Spark Rear-Facing Camera: adım 6, 1 resimden 1.
    • Then, simple lift to remove the metal battery cover.
  7. ZTE Blade Spark Rear-Facing Camera: adım 7, 1 resimden 1.
    • You have reached the Fingerprint Scanner, the device Battery, and Front Facing Camera.
  8. ZTE Blade Spark Rear-Facing Camera: adım 8, 3 resimden 1. ZTE Blade Spark Rear-Facing Camera: adım 8, 3 resimden 2. ZTE Blade Spark Rear-Facing Camera: adım 8, 3 resimden 3.
    • Proceeding with disassembly, next up is the top chipset which the Rear Facing Camera is attached to.
    • To detach the chipset and reach the Rear Camera, locate and disconnect five power connectors surrounding the top chipset (as shown in images).
  9. ZTE Blade Spark Rear-Facing Camera: adım 9, 1 resimden 1.
    • Once you have the power connectors disconnected from the top chipset, use a Phillips screwdriver to remove the final screw located at the very top of the chipset (as shown in image).
  10. ZTE Blade Spark Rear-Facing Camera: adım 10, 1 resimden 1.
    • Then, simply lift chipset from top and detach from the device frame.
  11. ZTE Blade Spark Rear-Facing Camera: adım 11, 1 resimden 1.
    • You have now reached the final replacement component of the device, the Rear Facing Camera!
    • For step-by-step instructions on replacing any of the device components covered throughout the disassembly process, check out our ZTE Blade Spark Replacement guides.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Hung Vu
632 İtibar
1 Kılavuz yazıldı
Ekip
Gateway, Team S1-G6, Johnson Spring 2018 Gateway, Team S1-G6, Johnson Spring 2018 üyesi
GCC-JOHNSON-S18S1G6
2 Üyeler
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 35
Her zaman: 2,279
