Ana içeriğe geç
ZTE Blade Spark Screen Replacement
Neye ihtiyacın var
  1. ZTE Blade Spark Screen Replacement, Screen: adım 1, 1 resimden 1.
    • Place phone screen side down on a flat surface.
  2. ZTE Blade Spark Screen Replacement: adım 2, 2 resimden 1. ZTE Blade Spark Screen Replacement: adım 2, 2 resimden 2.
    • Take an opening tool, and insert it between the phone's backplate and chassis.
    • Work the tool all the way around perimeter of the phone until the backplate is free.
  3. ZTE Blade Spark Screen Replacement: adım 3, 1 resimden 1.
    • Use a Phillips #00 screwdriver to carefully remove all fifteen 3.0 mm screws.
  4. ZTE Blade Spark Screen Replacement: adım 4, 1 resimden 1.
    • Remove the middle plate that was unscrewed from the previous step.
    • At this stage you should have 3 separate parts as shown.
    • For the next step you will be working on the middle part in this picture.
  5. ZTE Blade Spark Screen Replacement: adım 5, 1 resimden 1.
    • Take black covering off of battery.
  6. ZTE Blade Spark Screen Replacement: adım 6, 2 resimden 1. ZTE Blade Spark Screen Replacement: adım 6, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Unclip fastener located in the red box. Blunt end tweezers are recommended for this process.
  7. ZTE Blade Spark Screen Replacement: adım 7, 2 resimden 1. ZTE Blade Spark Screen Replacement: adım 7, 2 resimden 2.
    • Remove battery so you are left with the base of the phone, the battery, and the battery cover separated.
  8. ZTE Blade Spark Screen Replacement: adım 8, 1 resimden 1.
    • Remove the 4mm screws in the 2 red circles shown with the Phillips #00 screwdriver.
  9. ZTE Blade Spark Screen Replacement: adım 9, 1 resimden 1.
    • Heat all 4 sides of the piece with the iOpener to loosen adhesive.
  10. ZTE Blade Spark Screen Replacement: adım 10, 2 resimden 1. ZTE Blade Spark Screen Replacement: adım 10, 2 resimden 2.
    • Now remove the screen from it's base using the opening tool.
Sonuç
Swap your old screen with your new screen. To reassemble your device with a new screen, follow these instructions in reverse order.
Solomon Barket
181 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team 1-3, Harley Spring 2023 IUPUI, Team 1-3, Harley Spring 2023 üyesi
IUPUI-HARLEY-S23S1G3
3 Üyeler
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 9
Her zaman: 122
