Giriş
This car contains the charging port, headphone jack, and rear speaker.
The easiest way to replace any of the components on this board is to simply replace the entire board. Otherwise, you would have to desolder the faulty component and solder in a new one.
This replacement can be done without removing the battery, but due to the nature of the parts being replaced, it is highly recommended that the battery is removed before attempting this replacement.
Neye ihtiyacın var
Turn the device on it side with the buttons away from you.
Using the SIM Card Eject Tool, insert the narrow end into the ejection hole.
Press firmly into the hole until the SIM card tray pops out far enough to grab with your fingers.
Remove the one T2 screw from the side of the phone near where the SIM card tray was.
Use a spudger to pry up the the antenna connector on the top right of the charging port card.
9 farklı kişi bu kılavuzu tamamladı.
3 Yorum
Thanks! $7 part on ebay & this guide saved me from having to buy a new phone!!!
At the start of this procedure it stated to remove the battery. I never saw the battery being removed, or the power cable from the battery being disconnected from the board to isolate the power from the phone. Is this step necessary to replacing the charging port card. I know that the battery can be a bear removing it from the phone.
