Ana içeriğe geç
ZTE Grand X Max Plus Back Cover Replacement
Neye ihtiyacın var
  1. ZTE Grand X Max Plus Back Cover Replacement, Back Cover: adım 1, 1 resimden 1.
    • Make sure you turn off your phone before starting.
    • Heat the phone using a heating pad, heat gun, or hair dryer to loosen the glue. You just need to heat the back of the phone.
    • You can also use a hair dryer or a heating gun for this step.
    FixBot'a Sor
    Yorum Ekle
  2. ZTE Grand X Max Plus Back Cover Replacement: adım 2, 2 resimden 1. ZTE Grand X Max Plus Back Cover Replacement: adım 2, 2 resimden 2.
    • After the phone is heated, use the blue plastic opening tool on both sides of the phone.
    • Don't apply too much pressure because the cover can crack easily.
    • To avoid that your cover cracks, you can add tape to back cover.
    • You can use a suction cup to help remove the battery.
    FixBot'a Sor
    Yorum Ekle
  3. ZTE Grand X Max Plus Back Cover Replacement: adım 3, 2 resimden 1. ZTE Grand X Max Plus Back Cover Replacement: adım 3, 2 resimden 2.
    • Carefully remove the cover from the phone.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Jordano Baer
716 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S9-G4, Remmell Fall 2017 USF Tampa, Team S9-G4, Remmell Fall 2017 üyesi
USFT-REMMELL-F17S9G4
4 Üyeler
15 adet Kılavuz yazıldı
1Rehber Yorum
There seems to be an antenna attached to the mid frame that gets stuck to the back glass on the top left. Does anyone know what this is??
Kiki Jade - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 24
Her zaman: 742
