Ana içeriğe geç
ZTE Grand X Max Plus Battery Replacement
Neye ihtiyacın var
  1. ZTE Grand X Max Plus Battery Replacement, Back Cover: adım 1, 1 resimden 1.
    • Make sure you turn off your phone before starting.
    • Heat the phone using a heating pad, heat gun, or hair dryer to loosen the glue. You just need to heat the back of the phone.
    • You can also use a hair dryer or a heating gun for this step.
    FixBot'a Sor
    Yorum Ekle
  2. ZTE Grand X Max Plus Battery Replacement: adım 2, 2 resimden 1. ZTE Grand X Max Plus Battery Replacement: adım 2, 2 resimden 2.
    • After the phone is heated, use the blue plastic opening tool on both sides of the phone.
    • Don't apply too much pressure because the cover can crack easily.
    • To avoid that your cover cracks, you can add tape to back cover.
    • You can use a suction cup to help remove the battery.
    FixBot'a Sor
    Yorum Ekle
  3. ZTE Grand X Max Plus Battery Replacement: adım 3, 2 resimden 1. ZTE Grand X Max Plus Battery Replacement: adım 3, 2 resimden 2.
    • Carefully remove the cover from the phone.
    FixBot'a Sor
    Yorum Ekle
  4. ZTE Grand X Max Plus Battery Replacement, Battery: adım 4, 2 resimden 1. ZTE Grand X Max Plus Battery Replacement, Battery: adım 4, 2 resimden 2.
    • Use a plastic opening tool to pry the battery off.
    • The battery will be held down securely by glue, so it'll take quite a bit of sliding underneath to separate it from the compartment.
    FixBot'a Sor
    Yorum Ekle
  5. ZTE Grand X Max Plus Battery Replacement: adım 5, 3 resimden 1. ZTE Grand X Max Plus Battery Replacement: adım 5, 3 resimden 2. ZTE Grand X Max Plus Battery Replacement: adım 5, 3 resimden 3.
    • Pull up the piece that is connected to the motherboard. You can pull it using your nails.
    FixBot'a Sor
    Yorum Ekle
  6. ZTE Grand X Max Plus Battery Replacement: adım 6, 2 resimden 1. ZTE Grand X Max Plus Battery Replacement: adım 6, 2 resimden 2.
    • Remove the battery.
    FixBot'a Sor
    Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Jordano Baer
716 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S9-G4, Remmell Fall 2017 USF Tampa, Team S9-G4, Remmell Fall 2017 üyesi
USFT-REMMELL-F17S9G4
4 Üyeler
15 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 27
Her zaman: 3,299
