Ana içeriğe geç
ZTE Jasper LTE Screen Replacement
Neye ihtiyacın var
    1. ZTE Jasper LTE Screen Replacement, Battery: adım 1, 1 resimden 1.
      • Insert the spudger into the bottom left corner of the phone.
      • Use the spudger to loosen the back cover.
      FixBot'a Sor
      Yorum Ekle
    2. ZTE Jasper LTE Screen Replacement: adım 2, 1 resimden 1.
      • Insert the black spudger near the bottom left of the battery. There will be an opening to easily to remove the battery.
      • Continuing to use tool, prop up the battery and remove it.
      FixBot'a Sor
      Yorum Ekle
    1. ZTE Jasper LTE Screen Replacement, Camera: adım 3, 2 resimden 1. ZTE Jasper LTE Screen Replacement, Camera: adım 3, 2 resimden 2.
      • Remove nine 0.8mm Phillips #00 screws.
      FixBot'a Sor
      Yorum Ekle
    2. ZTE Jasper LTE Screen Replacement: adım 4, 2 resimden 1. ZTE Jasper LTE Screen Replacement: adım 4, 2 resimden 2.
      • Remove the back cover by pulling upwards.
      • Removing the back cover may take a bit of force.
      FixBot'a Sor
      Yorum Ekle
    3. ZTE Jasper LTE Screen Replacement: adım 5, 3 resimden 1. ZTE Jasper LTE Screen Replacement: adım 5, 3 resimden 2. ZTE Jasper LTE Screen Replacement: adım 5, 3 resimden 3.
      Bu adımda kullanılan alet:
      • Disconnect the gold component attached to the camera by pulling upwards using the tweezers.
      • Remove the camera using the tweezers by gripping tightly around the camera and pulling upwards.
      • Camera is attached to the motherboard with adhesive. As such, you may need to use light force to remove the camera.
      FixBot'a Sor
      Yorum Ekle
    1. ZTE Jasper LTE Screen Replacement, Screen: adım 6, 1 resimden 1.
      • Disconnect all of these parts from the motherboard.
      FixBot'a Sor
      Yorum Ekle
    2. ZTE Jasper LTE Screen Replacement: adım 7, 3 resimden 1. ZTE Jasper LTE Screen Replacement: adım 7, 3 resimden 2. ZTE Jasper LTE Screen Replacement: adım 7, 3 resimden 3.
      • Remove the 0.8mm Phillips #00 screw from the bottom right.
      • Disconnect the gold pin by pulling upwards with the tweezers.
      FixBot'a Sor
      Yorum Ekle
    3. ZTE Jasper LTE Screen Replacement: adım 8, 3 resimden 1. ZTE Jasper LTE Screen Replacement: adım 8, 3 resimden 2. ZTE Jasper LTE Screen Replacement: adım 8, 3 resimden 3.
      • Lightly disconnect the power button, volume button and the chip from the motherboard.
      • Be careful not to tear the volume and power button off the motherboard.
      FixBot'a Sor
      Yorum Ekle
    4. ZTE Jasper LTE Screen Replacement: adım 9, 2 resimden 1. ZTE Jasper LTE Screen Replacement: adım 9, 2 resimden 2.
      • Lightly move clip back to release the motherboard.
      • Gently pull the motherboard away from the screen.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Anthony Sou
391 İtibar
4 adet Kılavuz yazıldı
Ekip
UW Tacoma, Team S1-G1, Cardinal Spring 2019 UW Tacoma, Team S1-G1, Cardinal Spring 2019 üyesi
UWT-CARDINAL-S19S1G1
4 Üyeler
35 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 29
Her zaman: 490
