Ana içeriğe geç
ZTE Jasper LTE Screen Replacement
Neye ihtiyacın var
  1. ZTE Jasper LTE Screen Replacement, Battery: adım 1, 1 resimden 1.
    • Insert the spudger into the bottom left corner of the phone.
    • Use the spudger to loosen the back cover.
  2. ZTE Jasper LTE Screen Replacement: adım 2, 1 resimden 1.
    • Insert the black spudger near the bottom left of the battery. There will be an opening to easily to remove the battery.
    • Continuing to use tool, prop up the battery and remove it.
  3. ZTE Jasper LTE Screen Replacement, Camera: adım 3, 2 resimden 1. ZTE Jasper LTE Screen Replacement, Camera: adım 3, 2 resimden 2.
    • Remove nine 0.8mm Phillips #00 screws.
  4. ZTE Jasper LTE Screen Replacement: adım 4, 2 resimden 1. ZTE Jasper LTE Screen Replacement: adım 4, 2 resimden 2.
    • Remove the back cover by pulling upwards.
    • Removing the back cover may take a bit of force.
  5. ZTE Jasper LTE Screen Replacement: adım 5, 3 resimden 1. ZTE Jasper LTE Screen Replacement: adım 5, 3 resimden 2. ZTE Jasper LTE Screen Replacement: adım 5, 3 resimden 3.
    • Disconnect the gold component attached to the camera by pulling upwards using the tweezers.
    • Remove the camera using the tweezers by gripping tightly around the camera and pulling upwards.
    • Camera is attached to the motherboard with adhesive. As such, you may need to use light force to remove the camera.
  6. ZTE Jasper LTE Screen Replacement, Screen: adım 6, 1 resimden 1.
    • Disconnect all of these parts from the motherboard.
  7. ZTE Jasper LTE Screen Replacement: adım 7, 3 resimden 1. ZTE Jasper LTE Screen Replacement: adım 7, 3 resimden 2. ZTE Jasper LTE Screen Replacement: adım 7, 3 resimden 3.
    • Remove the 0.8mm Phillips #00 screw from the bottom right.
    • Disconnect the gold pin by pulling upwards with the tweezers.
  8. ZTE Jasper LTE Screen Replacement: adım 8, 3 resimden 1. ZTE Jasper LTE Screen Replacement: adım 8, 3 resimden 2. ZTE Jasper LTE Screen Replacement: adım 8, 3 resimden 3.
    • Lightly disconnect the power button, volume button and the chip from the motherboard.
    • Be careful not to tear the volume and power button off the motherboard.
  9. ZTE Jasper LTE Screen Replacement: adım 9, 2 resimden 1. ZTE Jasper LTE Screen Replacement: adım 9, 2 resimden 2.
    • Lightly move clip back to release the motherboard.
    • Gently pull the motherboard away from the screen.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Anthony Sou
391 İtibar
4 adet Kılavuz yazıldı
Ekip
UW Tacoma, Team S1-G1, Cardinal Spring 2019 UW Tacoma, Team S1-G1, Cardinal Spring 2019 üyesi
UWT-CARDINAL-S19S1G1
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 2
Her zaman: 233
