Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Giriş
This guide will demonstrate how to replace the front camera from the mother board of the ZTE Lever phone.
  1. Remove the SD card and the Sim card from the device.
    • Remove the SD card and the Sim card from the device.
    • The Sim and SD cards are not shown here as our device did not come with them.
  2. Use an iFixit opening tool to separate the back from the device. Use an iFixit opening tool to separate the back from the device.
    • Use an iFixit opening tool to separate the back from the device.
  3. Remove the two 1.6mm Phillips #0 screws from the battery plug cover. Remove the cover.
    • Remove the two 1.6mm Phillips #0 screws from the battery plug cover.
    • Remove the cover.
  4. Disconnect the battery cable from the motherboard with a plastic opening tool. Disconnect the battery cable from the motherboard with a plastic opening tool.
    • Disconnect the battery cable from the motherboard with a plastic opening tool.
  5. Use your hands, or a plastic opening tool, to pry the battery from the phone.
    • Use your hands, or a plastic opening tool, to pry the battery from the phone.
  6. Unscrew the three 1.6mm Philllips #0 screws on the plastic cover that are near the top edge of the phone by the camera. Pry off the plastic cover using the iFixit opening tool.
    • Unscrew the three 1.6mm Philllips #0 screws on the plastic cover that are near the top edge of the phone by the camera.
    • Pry off the plastic cover using the iFixit opening tool.
  7. Unplug the front-facing camera press fit connector cable using the iFixit opening tool. Remove the camera from the motherboard.
    • Unplug the front-facing camera press fit connector cable using the iFixit opening tool.
    • Remove the camera from the motherboard.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 69
