Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Use an iFixit opening tool to separate the back from the device.
Remove the two 1.6mm Phillips #0 screws from the battery plug cover.
Remove the cover.
Disconnect the battery cable from the motherboard with a plastic opening tool.
Use your hands, or a plastic opening tool, to pry the battery from the phone.
Unscrew the three 1.6mm Philllips #0 screws on the plastic cover that are near the top edge of the phone by the camera.
Pry off the plastic cover using the iFixit opening tool.
Unplug the front-facing camera press fit connector cable using the iFixit opening tool.
Remove the camera from the motherboard.
