Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Giriş
This guide will show you how to replace the loud speaker on a ZTE Lever smartphone.
  1. Remove the SD card and the Sim card from the device.
    • Remove the SD card and the Sim card from the device.
    • The Sim and SD cards are not shown here as our device did not come with them.
  2. Use an iFixit opening tool to separate the back from the device. Use an iFixit opening tool to separate the back from the device.
    • Use an iFixit opening tool to separate the back from the device.
  3. Remove the two 1.6mm Phillips #0 screws from the battery plug cover. Remove the cover.
    • Remove the two 1.6mm Phillips #0 screws from the battery plug cover.
    • Remove the cover.
  4. Disconnect the battery cable from the motherboard with a plastic opening tool. Disconnect the battery cable from the motherboard with a plastic opening tool.
    • Disconnect the battery cable from the motherboard with a plastic opening tool.
  5. Use your hands, or a plastic opening tool, to pry the battery from the phone.
    • Use your hands, or a plastic opening tool, to pry the battery from the phone.
  6. Remove the three 1.6mm Phillips #0 screws from the plastic cover on the motherboard.
    • Remove the three 1.6mm Phillips #0 screws from the plastic cover on the motherboard.
  7. Remove the top plastic motherboard cover using a plastic opening tool. Remove the top plastic motherboard cover using a plastic opening tool. Remove the top plastic motherboard cover using a plastic opening tool.
    • Remove the top plastic motherboard cover using a plastic opening tool.
  8. The Essential Toolkit
    The most helpful tools in our most compact kit.
    Hemen Alışveriş Yapın
  9. Use a plastic opening tool to flip up the retaining flap on the volume ribbon cable ZIF socket. Use a plastic opening tool to flip up the retaining flap on the volume ribbon cable ZIF socket.
    • Use a plastic opening tool to flip up the retaining flap on the volume ribbon cable ZIF socket.
  10. Peel up the volume button cable from the phone with hands, or plastic opening tool. Peel up the volume button cable from the phone with hands, or plastic opening tool.
    • Peel up the volume button cable from the phone with hands, or plastic opening tool.
  11. Disconnect the power button from the motherboard with a plastic opening tool.
    • Disconnect the power button from the motherboard with a plastic opening tool.
  12. Peel the power button cable up from the phone with you hands, or a plastic opening tool. Peel the power button cable up from the phone with you hands, or a plastic opening tool.
    • Peel the power button cable up from the phone with you hands, or a plastic opening tool.
  13. Remove the seven 1.6mm Phillips #0 screws from the plastic cover on the bottom of the motherboard. Remove the seven 1.6mm Phillips #0 screws from the plastic cover on the bottom of the motherboard.
    • Remove the seven 1.6mm Phillips #0 screws from the plastic cover on the bottom of the motherboard.
  14. Remove the bottom plastic motherboard cover with your fingers
    • Remove the bottom plastic motherboard cover with your fingers
  15. Disconnect the camera from the motherboard with a plastic opening tool. Disconnect the camera from the motherboard with a plastic opening tool.
    • Disconnect the camera from the motherboard with a plastic opening tool.
  16. Disconnect the display cable from the motherboard with a plastic opening tool.
    • Disconnect the display cable from the motherboard with a plastic opening tool.
  17. Disconnect the camera from the motherboard with a plastic opening tool. Disconnect the camera from the motherboard with a plastic opening tool. Disconnect the camera from the motherboard with a plastic opening tool.
  18. Disconnect the rear speaker cable from the motherboard with a plastic opening tool.
    • Disconnect the rear speaker cable from the motherboard with a plastic opening tool.
  19. Pry the motherboard cell battery from its position on the case of the phone
    • Pry the motherboard cell battery from its position on the case of the phone
  20. Using the plastic opening tool, pry the motherboard  up, sliding along the edge  to separate the pieces. Using the plastic opening tool, pry the motherboard  up, sliding along the edge  to separate the pieces. Using the plastic opening tool, pry the motherboard  up, sliding along the edge  to separate the pieces.
    • Using the plastic opening tool, pry the motherboard up, sliding along the edge to separate the pieces.
  21. Remove the motherboard with your fingers.
    • Remove the motherboard with your fingers.
  22. Using the plastic opening tool, remove the  speaker. Using the plastic opening tool, remove the  speaker.
    • Using the plastic opening tool, remove the speaker.
Sonuç
Luke Kilbourne
294 İtibar
2 adet Kılavuz yazıldı
Takım
USF Tampa, Team S5-G2, Passmore Spring 2018 USF Tampa, Team S5-G2, Passmore Spring 2018 üyesi
USFT-PASSMORE-S18S5G2
3 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 113
