Ana içeriğe geç
ZTE Lever Motherboard Replacement
Neye ihtiyacın var
  1. ZTE Lever Motherboard Replacement, Battery: adım 1, 1 resimden 1.
    • Remove the SD card and the Sim card from the device.
    • The Sim and SD cards are not shown here as our device did not come with them.
  2. ZTE Lever Motherboard Replacement: adım 2, 2 resimden 1. ZTE Lever Motherboard Replacement: adım 2, 2 resimden 2.
    • Use an iFixit opening tool to separate the back from the device.
  3. ZTE Lever Motherboard Replacement: adım 3, 2 resimden 1. ZTE Lever Motherboard Replacement: adım 3, 2 resimden 2.
    • Remove the two 1.6mm Phillips #0 screws from the battery plug cover.
    • Remove the cover.
  4. ZTE Lever Motherboard Replacement: adım 4, 2 resimden 1. ZTE Lever Motherboard Replacement: adım 4, 2 resimden 2.
    • Disconnect the battery cable from the motherboard with a plastic opening tool.
  5. ZTE Lever Motherboard Replacement: adım 5, 1 resimden 1.
    • Use your hands, or a plastic opening tool, to pry the battery from the phone.
  6. ZTE Lever Motherboard Replacement, Volume Buttons: adım 6, 1 resimden 1.
    • Remove the three 1.6mm Phillips #0 screws from the plastic cover on the motherboard.
  7. ZTE Lever Motherboard Replacement: adım 7, 3 resimden 1. ZTE Lever Motherboard Replacement: adım 7, 3 resimden 2. ZTE Lever Motherboard Replacement: adım 7, 3 resimden 3.
    • Remove the top plastic motherboard cover using a plastic opening tool.
  8. ZTE Lever Motherboard Replacement: adım 8, 2 resimden 1. ZTE Lever Motherboard Replacement: adım 8, 2 resimden 2.
    • Use a plastic opening tool to flip up the retaining flap on the volume ribbon cable ZIF socket.
  9. ZTE Lever Motherboard Replacement: adım 9, 2 resimden 1. ZTE Lever Motherboard Replacement: adım 9, 2 resimden 2.
    • Peel up the volume button cable from the phone with hands, or plastic opening tool.
  10. ZTE Lever Motherboard Replacement, Power Button: adım 10, 1 resimden 1.
    • Disconnect the power button from the motherboard with a plastic opening tool.
  11. ZTE Lever Motherboard Replacement: adım 11, 2 resimden 1. ZTE Lever Motherboard Replacement: adım 11, 2 resimden 2.
    • Peel the power button cable up from the phone with you hands, or a plastic opening tool.
  12. ZTE Lever Motherboard Replacement, Motherboard: adım 12, 2 resimden 1. ZTE Lever Motherboard Replacement, Motherboard: adım 12, 2 resimden 2.
    • Remove the seven 1.6mm Phillips #0 screws from the plastic cover on the bottom of the motherboard.
  13. ZTE Lever Motherboard Replacement: adım 13, 1 resimden 1.
    • Remove the bottom plastic motherboard cover with your fingers
  14. ZTE Lever Motherboard Replacement: adım 14, 2 resimden 1. ZTE Lever Motherboard Replacement: adım 14, 2 resimden 2.
    • Disconnect the camera from the motherboard with a plastic opening tool.
  15. ZTE Lever Motherboard Replacement: adım 15, 1 resimden 1.
    • Disconnect the display cable from the motherboard with a plastic opening tool.
  16. ZTE Lever Motherboard Replacement: adım 16, 3 resimden 1. ZTE Lever Motherboard Replacement: adım 16, 3 resimden 2. ZTE Lever Motherboard Replacement: adım 16, 3 resimden 3.
  17. ZTE Lever Motherboard Replacement: adım 17, 1 resimden 1.
    • Disconnect the rear speaker cable from the motherboard with a plastic opening tool.
  18. ZTE Lever Motherboard Replacement: adım 18, 1 resimden 1.
    • Pry the motherboard cell battery from its position on the case of the phone
  19. ZTE Lever Motherboard Replacement: adım 19, 3 resimden 1. ZTE Lever Motherboard Replacement: adım 19, 3 resimden 2. ZTE Lever Motherboard Replacement: adım 19, 3 resimden 3.
    • Using the plastic opening tool, pry the motherboard up, sliding along the edge to separate the pieces.
  20. ZTE Lever Motherboard Replacement: adım 20, 1 resimden 1.
    • Remove the motherboard with your fingers.
Sonuç
Luke Kilbourne
294 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S5-G2, Passmore Spring 2018 USF Tampa, Team S5-G2, Passmore Spring 2018 üyesi
USFT-PASSMORE-S18S5G2
3 Üyeler
12 adet Kılavuz yazıldı
Bir Yorum
Those are excellent instructions but I need to know where at on the motherboard is the internal memory storage cuz my phone is so screwed up that it won't charge or turn on or anything lol,so I got a different phone n got my SD card out of the ZTE n put in my new phone and there are some pics that I really need,but I was wondering if there was any way possible that I could put the SD card back in the ZTE motherboard and some how move the pics onto my SD card so I can have them on my new phone.This is killing my brain on trying to think of ways to succeed n can't please get back to me,,,thanks.
-ROGER-
Roger Knight - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 339
