Ana içeriğe geç
ZTE Lever Rear Camera Replacement
Neye ihtiyacın var
  1. ZTE Lever Rear Camera Replacement, Battery: adım 1, 1 resimden 1.
    • Remove the SD card and the Sim card from the device.
    • The Sim and SD cards are not shown here as our device did not come with them.
    FixBot'a Sor
    Yorum Ekle
  2. ZTE Lever Rear Camera Replacement: adım 2, 2 resimden 1. ZTE Lever Rear Camera Replacement: adım 2, 2 resimden 2.
    • Use an iFixit opening tool to separate the back from the device.
    FixBot'a Sor
    Yorum Ekle
  3. ZTE Lever Rear Camera Replacement: adım 3, 2 resimden 1. ZTE Lever Rear Camera Replacement: adım 3, 2 resimden 2.
    • Remove the two 1.6mm Phillips #0 screws from the battery plug cover.
    • Remove the cover.
    FixBot'a Sor
    Yorum Ekle
  4. ZTE Lever Rear Camera Replacement: adım 4, 2 resimden 1. ZTE Lever Rear Camera Replacement: adım 4, 2 resimden 2.
    • Disconnect the battery cable from the motherboard with a plastic opening tool.
    FixBot'a Sor
    Yorum Ekle
  5. ZTE Lever Rear Camera Replacement: adım 5, 1 resimden 1.
    • Use your hands, or a plastic opening tool, to pry the battery from the phone.
    FixBot'a Sor
    Yorum Ekle
  6. ZTE Lever Rear Camera Replacement, Rear Camera: adım 6, 1 resimden 1.
    • Remove the three 1.6mm Phillips #0 screws from the plastic cover on the motherboard.
    FixBot'a Sor
    Yorum Ekle
  7. ZTE Lever Rear Camera Replacement: adım 7, 3 resimden 1. ZTE Lever Rear Camera Replacement: adım 7, 3 resimden 2. ZTE Lever Rear Camera Replacement: adım 7, 3 resimden 3.
    • Remove the top plastic motherboard cover using a plastic opening tool.
    FixBot'a Sor
    Yorum Ekle
  8. ZTE Lever Rear Camera Replacement: adım 8, 2 resimden 1. ZTE Lever Rear Camera Replacement: adım 8, 2 resimden 2.
    • Using a plastic opening tool, disconnect the camera from the motherboard.
    FixBot'a Sor
    Yorum Ekle
  9. ZTE Lever Rear Camera Replacement: adım 9, 1 resimden 1.
    • Remove the camera from the phone.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Michael Gonzalez
501 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S5-G2, Passmore Spring 2018 USF Tampa, Team S5-G2, Passmore Spring 2018 üyesi
USFT-PASSMORE-S18S5G2
3 Üyeler
18 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 29
Her zaman: 361
