Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Giriş
Follow this guide to do a rear camera replacement on your ZTE Lever smart phone.
  1. Remove the SD card and the Sim card from the device.
    • Remove the SD card and the Sim card from the device.
    • The Sim and SD cards are not shown here as our device did not come with them.
  2. Use an iFixit opening tool to separate the back from the device. Use an iFixit opening tool to separate the back from the device.
    • Use an iFixit opening tool to separate the back from the device.
  3. Remove the two 1.6mm Phillips #0 screws from the battery plug cover. Remove the cover.
    • Remove the two 1.6mm Phillips #0 screws from the battery plug cover.
    • Remove the cover.
  4. The Essential Toolkit
    The most helpful tools in our most compact kit.
    Hemen Alışveriş Yapın
  5. Disconnect the battery cable from the motherboard with a plastic opening tool. Disconnect the battery cable from the motherboard with a plastic opening tool.
    • Disconnect the battery cable from the motherboard with a plastic opening tool.
  6. Use your hands, or a plastic opening tool, to pry the battery from the phone.
    • Use your hands, or a plastic opening tool, to pry the battery from the phone.
  7. Remove the three 1.6mm Phillips #0 screws from the plastic cover on the motherboard.
    • Remove the three 1.6mm Phillips #0 screws from the plastic cover on the motherboard.
  8. Remove the top plastic motherboard cover using a plastic opening tool. Remove the top plastic motherboard cover using a plastic opening tool. Remove the top plastic motherboard cover using a plastic opening tool.
    • Remove the top plastic motherboard cover using a plastic opening tool.
  9. Using a plastic opening tool, disconnect the camera from the motherboard. Using a plastic opening tool, disconnect the camera from the motherboard.
    • Using a plastic opening tool, disconnect the camera from the motherboard.
  10. Remove the camera from the phone.
    • Remove the camera from the phone.
Sonuç
Michael Gonzalez
466 İtibar
4 adet Kılavuz yazıldı
Takım
USF Tampa, Team S5-G2, Passmore Spring 2018 USF Tampa, Team S5-G2, Passmore Spring 2018 üyesi
USFT-PASSMORE-S18S5G2
3 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 61
