Ana içeriğe geç
ZTE Maven 2 Daughterboard Replacement
Neye ihtiyacın var
  1. ZTE Maven 2 Daughterboard Replacement, Back Cover: adım 1, 3 resimden 1. ZTE Maven 2 Daughterboard Replacement, Back Cover: adım 1, 3 resimden 2. ZTE Maven 2 Daughterboard Replacement, Back Cover: adım 1, 3 resimden 3.
    • Pry off the back cover by inserting an opening tool into the small space on the bottom left between the phone's cover and body.
    • Work your way around the phone with an opening pick to loosen the rest of the back cover.
    • Remove the cover.
  2. ZTE Maven 2 Daughterboard Replacement, Battery: adım 2, 1 resimden 1.
    • Push in and then up on the bottom of the battery to free it from its compartment.
    • Pull the battery out.
  3. ZTE Maven 2 Daughterboard Replacement, MicroSD Card: adım 3, 2 resimden 1. ZTE Maven 2 Daughterboard Replacement, MicroSD Card: adım 3, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Using your fingers or blunt tweezers, carefully pull the memory card out of the slot.
    • A SIM card is used to demonstrate the process for removing the MicroSD card in these images.
  4. ZTE Maven 2 Daughterboard Replacement, Midframe: adım 4, 1 resimden 1.
    • Remove the twelve 3 mm screws with a Phillips #00 screwdriver.
  5. ZTE Maven 2 Daughterboard Replacement: adım 5, 3 resimden 1. ZTE Maven 2 Daughterboard Replacement: adım 5, 3 resimden 2. ZTE Maven 2 Daughterboard Replacement: adım 5, 3 resimden 3.
    • Wedge the opening tool between the front and side panel to create a gap.
    • Slide the opening pick around the device to detach the midframe.
  6. ZTE Maven 2 Daughterboard Replacement, Motherboard: adım 6, 3 resimden 1. ZTE Maven 2 Daughterboard Replacement, Motherboard: adım 6, 3 resimden 2. ZTE Maven 2 Daughterboard Replacement, Motherboard: adım 6, 3 resimden 3.
    Satın Al
    • Peel the sticker off the battery compartment, as some of the motherboard components are hidden under it.
    • Remove the six 3 mm screws with a Phillips #00 screwdriver.
    • Using a pair of blunt tweezers, carefully remove the black wire that's attached to the gold plates on the left side of the device.
  7. ZTE Maven 2 Daughterboard Replacement: adım 7, 2 resimden 1. ZTE Maven 2 Daughterboard Replacement: adım 7, 2 resimden 2.
    • Using the opening tool, carefully detach the ribbon cables connected to the motherboard.
  8. ZTE Maven 2 Daughterboard Replacement: adım 8, 2 resimden 1. ZTE Maven 2 Daughterboard Replacement: adım 8, 2 resimden 2.
    • Work the opening pick around the edges of the motherboard to loosen it up.
    • The motherboard is glued down with adhesive. Pushing firmly with the pick will help to loosen the components and remove them.
    • Pull the motherboard out of the device.
  9. ZTE Maven 2 Daughterboard Replacement, Daughterboard: adım 9, 1 resimden 1.
    • Remove the daughterboard containing the charging port.
Sonuç
Kristen Gismondi
82.704 İtibar
202 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
136 Üyeler
17.430 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 2
Her zaman: 23
