Giriş
This guide will show you how to access and remove the MicroSD card in your ZTE Maven 2 (model Z831). The MicroSD is a memory card that stores information on the phone. It may need to be removed or replaced for issues with storage capacity.
Neye ihtiyacın var
Pry off the back cover by inserting an opening tool into the small space on the bottom left between the phone's cover and body.
Work your way around the phone with an opening pick to loosen the rest of the back cover.
Remove the cover.
Bu adımda kullanılan alet:Tweezers$4.99
Using your fingers or blunt tweezers, carefully pull the memory card out of the slot.
