Ana içeriğe geç
ZTE Maven 3 Back Camera Replacement
Neye ihtiyacın var
    1. ZTE Maven 3 Back Camera Replacement, Back Cover: adım 1, 3 resimden 1. ZTE Maven 3 Back Camera Replacement, Back Cover: adım 1, 3 resimden 2. ZTE Maven 3 Back Camera Replacement, Back Cover: adım 1, 3 resimden 3.
      • Locate the small indent on the back right bottom corner of the phone.
      • Put the pry tool or your fingertip inside the small gap on the bottom right of the back of the phone and pop up the cover.
      • Continue to go around the phone until the cover is completely off the back of the pull and put it aside.
      FixBot'a Sor
      Yorum Ekle
    1. ZTE Maven 3 Back Camera Replacement, Battery: adım 2, 3 resimden 1. ZTE Maven 3 Back Camera Replacement, Battery: adım 2, 3 resimden 2. ZTE Maven 3 Back Camera Replacement, Battery: adım 2, 3 resimden 3.
      • Locate the battery in the middle of the back of the phone.
      • Push in and up on the battery to remove it from its slot.
      • Put the battery aside.
      FixBot'a Sor
      Yorum Ekle
    1. ZTE Maven 3 Back Camera Replacement, Midframe: adım 3, 1 resimden 1.
      • Use a Phillips #00 screwdriver to remove twelve 2 mm screws along the back outer edges of the phone.
      FixBot'a Sor
      Yorum Ekle
    2. ZTE Maven 3 Back Camera Replacement: adım 4, 1 resimden 1.
      • There’s a 13th 2 mm screw with a lock sticker over it on the bottom right corner. Insert the #00 Phillips screwdriver in the middle, breaking the sticker, and take the screw out.
      FixBot'a Sor
      Yorum Ekle
    3. ZTE Maven 3 Back Camera Replacement: adım 5, 2 resimden 1. ZTE Maven 3 Back Camera Replacement: adım 5, 2 resimden 2.
      • Slide the pry tool into the middle of the connection between the screen and the back of the phone.
      • Once in, slide the pry tool around the phone, separating the screen and the back of the phone.
      • The detached piece is the midframe, and you can place it aside when detached.
      FixBot'a Sor
      Yorum Ekle
    1. ZTE Maven 3 Back Camera Replacement, Back Camera: adım 6, 2 resimden 1. ZTE Maven 3 Back Camera Replacement, Back Camera: adım 6, 2 resimden 2.
      Bu adımda kullanılan alet:
      • Detach the ribbon cable connecting the camera in the top middle of the phone.
      • Use blunt tweezers to pull the camera off and put it aside.
      • Using this same method, grab the tweezers and insert the replacement camera.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Jasmine Turner
91 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 3-1, Konn Fall 2023 UMass Dartmouth, Team 3-1, Konn Fall 2023 üyesi
UMASSD-KONN-F23S3G1
3 Üyeler
70 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 26
Her zaman: 312
