Giriş
Replacing the daughterboard or charging port in a phone becomes necessary when these components suffer damage or malfunction, leading to charging issues or connectivity problems. Physical damage, corrosion, or wear and tear can impair the functionality of the charging port, resulting in difficulties charging the device or establishing connections with other devices.
Swapping out these components ensures seamless charging, data transfer capabilities, and overall usability of the phone.
Neye ihtiyacın var
Locate the small indent on the back right bottom corner of the phone.
Put the pry tool or your fingertip inside the small gap on the bottom right of the back of the phone and pop up the cover.
Continue to go around the phone until the cover is completely off the back of the pull and put it aside.
Locate the battery in the middle of the back of the phone.
Push in and up on the battery to remove it from its slot.
Put the battery aside.
Use a Phillips #00 screwdriver to remove twelve 2 mm screws along the back outer edges of the phone.
Use the Phillips #00 screwdriver and remove the four 2 mm screws that are located around the edges.
Use your fingertips or pry gently with a plastic tool to remove the daughterboard.
