Ana içeriğe geç
ZTE Maven 3 Daughterboard Replacement
Neye ihtiyacın var
  1. ZTE Maven 3 Daughterboard Replacement, Back Cover: adım 1, 3 resimden 1. ZTE Maven 3 Daughterboard Replacement, Back Cover: adım 1, 3 resimden 2. ZTE Maven 3 Daughterboard Replacement, Back Cover: adım 1, 3 resimden 3.
    • Locate the small indent on the back right bottom corner of the phone.
    • Put the pry tool or your fingertip inside the small gap on the bottom right of the back of the phone and pop up the cover.
    • Continue to go around the phone until the cover is completely off the back of the pull and put it aside.
  2. ZTE Maven 3 Daughterboard Replacement, Battery: adım 2, 3 resimden 1. ZTE Maven 3 Daughterboard Replacement, Battery: adım 2, 3 resimden 2. ZTE Maven 3 Daughterboard Replacement, Battery: adım 2, 3 resimden 3.
    • Locate the battery in the middle of the back of the phone.
    • Push in and up on the battery to remove it from its slot.
    • Put the battery aside.
  3. ZTE Maven 3 Daughterboard Replacement, Midframe: adım 3, 1 resimden 1.
    • Use a Phillips #00 screwdriver to remove twelve 2 mm screws along the back outer edges of the phone.
  4. ZTE Maven 3 Daughterboard Replacement: adım 4, 1 resimden 1.
    • There’s a 13th 2 mm screw with a lock sticker over it on the bottom right corner. Insert the #00 Phillips screwdriver in the middle, breaking the sticker, and take the screw out.
  5. ZTE Maven 3 Daughterboard Replacement: adım 5, 2 resimden 1. ZTE Maven 3 Daughterboard Replacement: adım 5, 2 resimden 2.
    • Slide the pry tool into the middle of the connection between the screen and the back of the phone.
    • Once in, slide the pry tool around the phone, separating the screen and the back of the phone.
    • The detached piece is the midframe, and you can place it aside when detached.
  6. ZTE Maven 3 Daughterboard Replacement, Motherboard: adım 6, 1 resimden 1.
    • Use the Phillips #00 screwdriver and remove the four 2 mm screws that are located around the edges.
  7. ZTE Maven 3 Daughterboard Replacement: adım 7, 1 resimden 1.
    Bu adımda kullanılan alet:
    Satın Al
    • Please locate the black wire that’s attached to gold plates on the left side of the device.
    • Using a pair of tweezers, carefully grab the black wire and detach it, then remove it.
  8. ZTE Maven 3 Daughterboard Replacement: adım 8, 2 resimden 1. ZTE Maven 3 Daughterboard Replacement: adım 8, 2 resimden 2.
    • Using the tweezers, carefully detach the six ribbon cables also located along the edges.
    • 2 adhesive ribbon cables (green circles).
    • One ribbon cable that slides out (orange circles).
    • Three ribbon cables that pop in and out (yellow circles).
  9. ZTE Maven 3 Daughterboard Replacement: adım 9, 3 resimden 1. ZTE Maven 3 Daughterboard Replacement: adım 9, 3 resimden 2. ZTE Maven 3 Daughterboard Replacement: adım 9, 3 resimden 3.
    • You will also have to detach the two cameras by detaching the ribbon cable using the tweezers as well. Put those off to the side.
  10. ZTE Maven 3 Daughterboard Replacement: adım 10, 2 resimden 1. ZTE Maven 3 Daughterboard Replacement: adım 10, 2 resimden 2.
    • Grab the opening pick and work it into the edges of the motherboard.
    • Make sure you are firmly pushing the pick to loosen the motherboard since it is placed with adhesive.
    • Remove the motherboard and put it aside.
  11. ZTE Maven 3 Daughterboard Replacement, Daughterboard/Charging Port: adım 11, 2 resimden 1. ZTE Maven 3 Daughterboard Replacement, Daughterboard/Charging Port: adım 11, 2 resimden 2.
    • Use your fingertips or pry gently with a plastic tool to remove the daughterboard.
Sonuç
Emma Thiboutot
699 İtibar
8 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 3-1, Konn Fall 2023 UMass Dartmouth, Team 3-1, Konn Fall 2023 üyesi
UMASSD-KONN-F23S3G1
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 34
