Ana içeriğe geç
ZTE Max XL Motherboard Replacement
Neye ihtiyacın var
  1. ZTE Max XL Motherboard Replacement, Motherboard: adım 1, 2 resimden 1. ZTE Max XL Motherboard Replacement, Motherboard: adım 1, 2 resimden 2.
    • Before any disassembly, make sure the phone is powered off.
    • Use the SIM Card Eject Tool to remove the SIM card tray. To do this, insert the key into the hole on the side of the phone near the SIM card tray.
  2. ZTE Max XL Motherboard Replacement: adım 2, 1 resimden 1.
    • Apply the iOpener to the back of the phone. For instructions on how to use the iOpener, use this guide.
    • On our phone there was adhesive on the top and bottom of the phone backing, so we specifically heated these areas.
    • Do not heat the phone too much in one area - it may warp the plastic backing.
  3. ZTE Max XL Motherboard Replacement: adım 3, 3 resimden 1. ZTE Max XL Motherboard Replacement: adım 3, 3 resimden 2. ZTE Max XL Motherboard Replacement: adım 3, 3 resimden 3.
    • Starting at one corner, wedge a plastic opening pick or tool underneath the plastic backing to start undoing the tabs that connect the backing to the phone.
    • There are 3 tabs on top and bottom and 6 on each side.
  4. ZTE Max XL Motherboard Replacement: adım 4, 2 resimden 1. ZTE Max XL Motherboard Replacement: adım 4, 2 resimden 2.
    • Remove the two 3.4 mm JIS #00 screws that hold the cable in place—one may be under a lock sticker.
  5. ZTE Max XL Motherboard Replacement: adım 5, 1 resimden 1.
    • Use a nylon spudger to lift the press-fit connector and free the ribbon cable from the main part of the phone.
  6. ZTE Max XL Motherboard Replacement: adım 6, 1 resimden 1.
    • Remove all nineteen 3.4 mm JIS #00 screws from the perimeter of the back.
  7. ZTE Max XL Motherboard Replacement: adım 7, 1 resimden 1.
    • Use an opening tool between the screen and side trim battery cover to remove the screen.
  8. ZTE Max XL Motherboard Replacement: adım 8, 2 resimden 1. ZTE Max XL Motherboard Replacement: adım 8, 2 resimden 2.
    • Use a nylon spudger to carefully lift the 6 press-fit connections free from the motherboard.
  9. ZTE Max XL Motherboard Replacement: adım 9, 2 resimden 1. ZTE Max XL Motherboard Replacement: adım 9, 2 resimden 2.
    • Use the Spudger to carefully flip the metal clip holding the camera in place, located on the backside of the Motherboard.
  10. ZTE Max XL Motherboard Replacement: adım 10, 1 resimden 1.
    • With the motherboard removed, you can now insert the new motherboard or replace other parts within your phone.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Juan Espejo
211 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team 1-2, Harley Spring 2022 IUPUI, Team 1-2, Harley Spring 2022 üyesi
IUPUI-HARLEY-S22S1G2
4 Üyeler
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 134
