Ana içeriğe geç
ZTE Max XL Rear-Facing Camera Replacement
Neye ihtiyacın var
  1. ZTE Max XL Rear-Facing Camera Replacement, Rear-Facing Camera: adım 1, 2 resimden 1. ZTE Max XL Rear-Facing Camera Replacement, Rear-Facing Camera: adım 1, 2 resimden 2.
    • Before disassembly, make sure that the phone is powered off.
    • Remove the SIM Card tray using the SIM Card remover key. Insert the tool into the hole on the side of the phone near the SIM Card tray.
  2. ZTE Max XL Rear-Facing Camera Replacement: adım 2, 1 resimden 1.
    • To break up any adhesive that connects the back plastic piece to the phone, apply the iOpener to the back of the phone. For instructions on how to use the iOpener please follow this guide.
    • On our phone there was adhesive on the top of the phone backing, so we specifically heated this area.
    • Do not heat the phone too much in one area - it may warp the plastic backing.
  3. ZTE Max XL Rear-Facing Camera Replacement: adım 3, 3 resimden 1. ZTE Max XL Rear-Facing Camera Replacement: adım 3, 3 resimden 2. ZTE Max XL Rear-Facing Camera Replacement: adım 3, 3 resimden 3.
    • Starting at one corner, wedge a plastic opening pick or tool underneath the plastic backing to start undoing the tabs that connect the backing to the phone.
    • There are 3 tabs on top and bottom and 6 on each side.
  4. ZTE Max XL Rear-Facing Camera Replacement: adım 4, 2 resimden 1. ZTE Max XL Rear-Facing Camera Replacement: adım 4, 2 resimden 2.
    • Remove the two 3.4 mm JIS #00 screws that hold the cable in place—one may be under a lock sticker.
  5. ZTE Max XL Rear-Facing Camera Replacement: adım 5, 1 resimden 1.
    • Use a nylon spudger to lift the press-fit connector and free the ribbon cable from the main part of the phone.
  6. ZTE Max XL Rear-Facing Camera Replacement: adım 6, 1 resimden 1.
    • Remove all nineteen 3.4 mm JIS #00 screws from the perimeter of the back.
  7. ZTE Max XL Rear-Facing Camera Replacement: adım 7, 1 resimden 1.
    • Use an opening tool between the screen and side trim battery cover to remove the screen.
  8. ZTE Max XL Rear-Facing Camera Replacement: adım 8, 2 resimden 1. ZTE Max XL Rear-Facing Camera Replacement: adım 8, 2 resimden 2.
    • Use a nylon spudger to carefully lift the 6 press-fit connections free from the motherboard.
  9. ZTE Max XL Rear-Facing Camera Replacement: adım 9, 2 resimden 1. ZTE Max XL Rear-Facing Camera Replacement: adım 9, 2 resimden 2.
    • Use a nylon spudger to carefully lift the camera ribbon cable's press-fit connector free from the motherboard.
    • With the metal connector detached, the rear-facing camera is disconnected from the phone and can be replaced.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Blake Robbins
190 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team 1-2, Harley Spring 2022 IUPUI, Team 1-2, Harley Spring 2022 üyesi
IUPUI-HARLEY-S22S1G2
4 Üyeler
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 106
