Ana içeriğe geç
ZTE Prestige 2 Speaker Replacement
Neye ihtiyacın var
  1. ZTE Prestige 2 Speaker Replacement, Battery: adım 1, 3 resimden 1. ZTE Prestige 2 Speaker Replacement, Battery: adım 1, 3 resimden 2. ZTE Prestige 2 Speaker Replacement, Battery: adım 1, 3 resimden 3.
    • Use the iFixit opening tool to open up the device by wedging the tool under the back case and popping it open.
  2. ZTE Prestige 2 Speaker Replacement: adım 2, 2 resimden 1. ZTE Prestige 2 Speaker Replacement: adım 2, 2 resimden 2.
    • Remove the battery.
  3. ZTE Prestige 2 Speaker Replacement, Back Panel: adım 3, 3 resimden 1. ZTE Prestige 2 Speaker Replacement, Back Panel: adım 3, 3 resimden 2. ZTE Prestige 2 Speaker Replacement, Back Panel: adım 3, 3 resimden 3.
    • Use a Phillips #00 screwdriver to unscrew all 12 of the 3 mm Phillips screws located along the edges of the device’s back panel, as well as the blue 3mm Phillips screw labeled “ZTE” located towards the top right.
  4. ZTE Prestige 2 Speaker Replacement: adım 4, 3 resimden 1. ZTE Prestige 2 Speaker Replacement: adım 4, 3 resimden 2. ZTE Prestige 2 Speaker Replacement: adım 4, 3 resimden 3.
    • Then use the iFixit opening tool and wedge it under the grey back panel and pop it off.
    • There will be a lot of resistance, apply adequate pressure.
    • Use the Hakko 5B SA curved tweezers to dig under the top slit of the speaker and pull upwards.
  5. ZTE Prestige 2 Speaker Replacement: adım 6, 2 resimden 1. ZTE Prestige 2 Speaker Replacement: adım 6, 2 resimden 2.
    • Use the curved tweezers to grab onto one of the corners of the speaker and pull upwards and lift out.
Sonuç
Maria Stock
524 İtibar
5 adet Kılavuz yazıldı
Ekip
UW Stout, Team S1-G4, Schneider-Bateman Spring 2020 UW Stout, Team S1-G4, Schneider-Bateman Spring 2020 üyesi
UWSTOUT-SCHNEIDER-BATEMAN-S20S1G4
3 Üyeler
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 90
