Ana içeriğe geç
ZTE Quest n817 Daughterboard Replacement
Neye ihtiyacın var
  1. ZTE Quest n817 Daughterboard Replacement, Battery: adım 1, 3 resimden 1. ZTE Quest n817 Daughterboard Replacement, Battery: adım 1, 3 resimden 2. ZTE Quest n817 Daughterboard Replacement, Battery: adım 1, 3 resimden 3.
    • Ensure that the phone is turned off before starting.
    • Orient the device so that the inset on the right side of the device is facing you.
    • Insert the spudger into the inset and carefully remove the back panel.
  2. ZTE Quest n817 Daughterboard Replacement: adım 2, 2 resimden 1. ZTE Quest n817 Daughterboard Replacement: adım 2, 2 resimden 2.
    • Use the ribbon to remove the exposed battery.
  3. ZTE Quest n817 Daughterboard Replacement, Daughterboard: adım 3, 1 resimden 1.
    • Carefully pry open the back panel with the plastic opening tool.
  4. ZTE Quest n817 Daughterboard Replacement: adım 4, 1 resimden 1.
    • Unplug the flat-top connector by lifting each side of the connector up before fully removing it from its socket.
  5. ZTE Quest n817 Daughterboard Replacement: adım 5, 1 resimden 1.
    • Remove the two 2.0mm screws on either side of the daughterboard.
  6. ZTE Quest n817 Daughterboard Replacement: adım 6, 1 resimden 1.
    • Remove the coaxial connector that links the daughterboard to the motherboard.
Sonuç
Eric Loureiro
582 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S3-G6, Peak Fall 2018 UMass Dartmouth, Team S3-G6, Peak Fall 2018 üyesi
UMASSD-PEAK-F18S3G6
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 7
Her zaman: 242
