Ana içeriğe geç
ZTE Speed Front and Back Camera Replacement
Neye ihtiyacın var
  1. ZTE Speed Front and Back Camera Replacement, Front and Back Camera: adım 1, 2 resimden 1. ZTE Speed Front and Back Camera Replacement, Front and Back Camera: adım 1, 2 resimden 2.
    • Pull off back cover at bottom right corner.
  2. ZTE Speed Front and Back Camera Replacement: adım 2, 2 resimden 1. ZTE Speed Front and Back Camera Replacement: adım 2, 2 resimden 2.
    • Remove the seven 3.175mm Phillips head screws from the inner back located at the top, upper-middle-right, middle-right, lower-right, and bottom.
  3. ZTE Speed Front and Back Camera Replacement: adım 3, 2 resimden 1. ZTE Speed Front and Back Camera Replacement: adım 3, 2 resimden 2.
    • With the plastic opening tool the spudger, gently pry off the inner back seal around the phone.
    • Be careful not to pry it off too harsh, as it is just plastic.
  4. ZTE Speed Front and Back Camera Replacement: adım 4, 2 resimden 1. ZTE Speed Front and Back Camera Replacement: adım 4, 2 resimden 2.
    • With the spudger, gently pry off camera at the top-middle of the phone to get back camera.
    • With the spudger, gently pry off camera at the top-left of the phone to get the front camera.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Garrett Barry
722 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 6-3, Bhusal Spring 2016 UMass Dartmouth, Team 6-3, Bhusal Spring 2016 üyesi
UMASSD-BHUSAL-S16S6G3
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 11
Her zaman: 321
