Ana içeriğe geç
ZTE Speed Headphone Jack Replacement
Neye ihtiyacın var
  1. ZTE Speed Headphone Jack Replacement, Motherboard: adım 1, 2 resimden 1. ZTE Speed Headphone Jack Replacement, Motherboard: adım 1, 2 resimden 2.
    • Pull off back cover at bottom right corner.
  2. ZTE Speed Headphone Jack Replacement: adım 2, 2 resimden 1. ZTE Speed Headphone Jack Replacement: adım 2, 2 resimden 2.
    • Remove the seven 3.175mm Phillips head screws from the inner back located at the top, upper-middle-right, middle-right, lower-right, and bottom.
  3. ZTE Speed Headphone Jack Replacement: adım 3, 2 resimden 1. ZTE Speed Headphone Jack Replacement: adım 3, 2 resimden 2.
    • With the plastic opening tool the spudger, gently pry off the inner back.
    • Be careful not to pry it off too hard, as it is just a plastic covering.
  4. ZTE Speed Headphone Jack Replacement: adım 4, 1 resimden 1.
    • Remove the one 2.381mm Phillips head screw from the motherboard located in the upper-middle part of the phone next to the bottom left corner of the back camera.
  5. ZTE Speed Headphone Jack Replacement: adım 5, 3 resimden 1. ZTE Speed Headphone Jack Replacement: adım 5, 3 resimden 2. ZTE Speed Headphone Jack Replacement: adım 5, 3 resimden 3.
    • Using the spudger, gently pry up all ZIF connectors
    • ZIF connectors have a tiny tab that needs to be flipped up in order to safely remove the cable
    • Using same spudger, gently pry up the orange flat top connector
  6. ZTE Speed Headphone Jack Replacement: adım 6, 2 resimden 1. ZTE Speed Headphone Jack Replacement: adım 6, 2 resimden 2.
    • Carefully take off motherboard.
  7. ZTE Speed Headphone Jack Replacement, Headphone Jack: adım 7, 2 resimden 1. ZTE Speed Headphone Jack Replacement, Headphone Jack: adım 7, 2 resimden 2.
    • Flip over motherboard to locate headphone jack circuit.
Sonuç
Garrett Barry
722 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 6-3, Bhusal Spring 2016 UMass Dartmouth, Team 6-3, Bhusal Spring 2016 üyesi
UMASSD-BHUSAL-S16S6G3
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 11
Her zaman: 247
