Ana içeriğe geç
ZTE Telstra T95 Charging Port Replacement
Neye ihtiyacın var
  1. ZTE Telstra T95 Charging Port Replacement, Battery: adım 1, 1 resimden 1.
    • Remove the back cover using a plastic opening tool. Insert it into each corner starting at the upper left of the back cover and pushing out.
    • You may also use your finger nail if you do not have a plastic opening tool at hand.
  2. ZTE Telstra T95 Charging Port Replacement: adım 2, 1 resimden 1.
    • Using a plastic opening tool, push out the battery by inserting it into the small groove at the top left corner of the battery and pushing out.
    • The battery snaps out of place and you can remove it using your fingers.
    • When you are ready to insert a battery make sure the three copper teeth on the phone are aligned with the 3 copper dents on the battery.
  3. ZTE Telstra T95 Charging Port Replacement, SIM Card: adım 3, 1 resimden 1.
  4. ZTE Telstra T95 Charging Port Replacement: adım 4, 1 resimden 1.
    • Using your a plastic opening tool, push out the battery by inserting it into the small groove at the top left corner of the battery and pushing out.
  5. ZTE Telstra T95 Charging Port Replacement: adım 5, 2 resimden 1. ZTE Telstra T95 Charging Port Replacement: adım 5, 2 resimden 2.
    • Remove the SIM card by placing your index finger over it and sliding it out.
    • When you are ready to re-insert the SIM card make sure the pink side facing up.
  6. ZTE Telstra T95 Charging Port Replacement, Keypad: adım 6, 1 resimden 1.
    • Unscrew the phone casing using a small screw driver. Remove the four screws on each corner on the back of the phone.
    • Screw sizes are 1.42mm in width and 3.37mm in length.
  7. ZTE Telstra T95 Charging Port Replacement: adım 7, 1 resimden 1.
    • Remove front casing by sliding a plastic opening tool between the chrome layer and the top cover.
  8. ZTE Telstra T95 Charging Port Replacement: adım 8, 1 resimden 1.
    • The buttons should come off with the front casing but sometimes they don't. If that is the case simply remove them using your fingers and place them with the front cover.
    • If your keypad buttons are sticky you can clean them in this step.
  9. ZTE Telstra T95 Charging Port Replacement, Charging Port: adım 9, 1 resimden 1.
    • The back casing is removed by taking the motherboard and back casing and pulling them apart.
  10. ZTE Telstra T95 Charging Port Replacement: adım 10, 1 resimden 1.
    Bu adımda kullanılan alet:
    Satın Al
    • The charging port is a square piece at the bottom center of the phone that is sticking out.
    • If it is is loose simply remove it.
    • If it is still attached you must remove the charging port using the heat pen on your soldering station on top of the charging port until it becomes loose.
    • Gently remove the charging port using tweezers.
    • At this point you can solder the new charging port.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Iris Ortega
394 İtibar
2 adet Kılavuz yazıldı
Ekip
Gateway, Team 1-1, Johnson Fall 2014 Gateway, Team 1-1, Johnson Fall 2014 üyesi
GCC-JOHNSON-F14S1G1
3 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 13
Her zaman: 760
