Ana içeriğe geç
ZTE Telstra T95 SIM Card Replacement
    1. ZTE Telstra T95 SIM Card Replacement, Battery: adım 1, 1 resimden 1.
      • Remove the back cover using a plastic opening tool. Insert it into each corner starting at the upper left of the back cover and pushing out.
      • You may also use your finger nail if you do not have a plastic opening tool at hand.
      FixBot'a Sor
      Yorum Ekle
    2. ZTE Telstra T95 SIM Card Replacement: adım 2, 1 resimden 1.
      • Using a plastic opening tool, push out the battery by inserting it into the small groove at the top left corner of the battery and pushing out.
      • The battery snaps out of place and you can remove it using your fingers.
      • When you are ready to insert a battery make sure the three copper teeth on the phone are aligned with the 3 copper dents on the battery.
      FixBot'a Sor
      Yorum Ekle
    1. ZTE Telstra T95 SIM Card Replacement, SIM Card: adım 3, 1 resimden 1.
      FixBot'a Sor
      Yorum Ekle
    2. ZTE Telstra T95 SIM Card Replacement: adım 4, 1 resimden 1.
      • Using your a plastic opening tool, push out the battery by inserting it into the small groove at the top left corner of the battery and pushing out.
      FixBot'a Sor
      Yorum Ekle
    3. ZTE Telstra T95 SIM Card Replacement: adım 5, 2 resimden 1. ZTE Telstra T95 SIM Card Replacement: adım 5, 2 resimden 2.
      • Remove the SIM card by placing your index finger over it and sliding it out.
      • When you are ready to re-insert the SIM card make sure the pink side facing up.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Jeesenia Rios
300 İtibar
2 adet Kılavuz yazıldı
Ekip
Gateway, Team 1-1, Johnson Fall 2014 Gateway, Team 1-1, Johnson Fall 2014 üyesi
GCC-JOHNSON-F14S1G1
3 Üyeler
24 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 29
Her zaman: 1,251
