Ana içeriğe geç
ZTE Tempo Front Camera Replacement
Neye ihtiyacın var
  1. ZTE Tempo Front Camera Replacement, Front Camera: adım 1, 3 resimden 1. ZTE Tempo Front Camera Replacement, Front Camera: adım 1, 3 resimden 2. ZTE Tempo Front Camera Replacement, Front Camera: adım 1, 3 resimden 3.
    • Pry open the back case to get to the back cover.
    • Remove eight 5mm screws with a PH0 screw.
    • Pry open the back cover with a plastic opening tool.
    • Slide the plastic opening tool alongside the side seam twisting your hand forcefully to open the back cover.
    • Note: Pry open by finding an edge and forcing it open with the plastic opening tool.
  2. ZTE Tempo Front Camera Replacement: adım 2, 3 resimden 1. ZTE Tempo Front Camera Replacement: adım 2, 3 resimden 2. ZTE Tempo Front Camera Replacement: adım 2, 3 resimden 3.
    • Use a plastic opening tool to lift the press-fit connector up and disconnect the battery ribbon cable.
    • Lift the battery up and remove it from the phone.
  3. ZTE Tempo Front Camera Replacement: adım 3, 2 resimden 1. ZTE Tempo Front Camera Replacement: adım 3, 2 resimden 2.
    • Use a plastic opening tool to lift the press-fit connector up and disconnect the front camera ribbon cable.
    • Lift the front camera out of the phone.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 13
Her zaman: 139
