Ana içeriğe geç
ZTE Tempo Front Screen Assembly Replacement
Neye ihtiyacın var
  1. ZTE Tempo Front Screen Assembly Replacement, Battery: adım 1, 2 resimden 1. ZTE Tempo Front Screen Assembly Replacement, Battery: adım 1, 2 resimden 2.
    • Use a plastic opening tool to pry open the back case.
    • Use a Phillips #0 screwdriver to remove the eight 5mm screws.
    • Use a plastic opening tool to remove the midframe.
  2. ZTE Tempo Front Screen Assembly Replacement: adım 2, 3 resimden 1. ZTE Tempo Front Screen Assembly Replacement: adım 2, 3 resimden 2. ZTE Tempo Front Screen Assembly Replacement: adım 2, 3 resimden 3.
    • Use a plastic opening tool to lift the press-fit connector up and disconnect the battery ribbon cable.
    • Lift the battery up and remove it from the phone.
  3. ZTE Tempo Front Screen Assembly Replacement, Front Screen Assembly: adım 3, 3 resimden 1. ZTE Tempo Front Screen Assembly Replacement, Front Screen Assembly: adım 3, 3 resimden 2. ZTE Tempo Front Screen Assembly Replacement, Front Screen Assembly: adım 3, 3 resimden 3.
    • Use the plastic opening tool to unplug the three connectors.
  4. ZTE Tempo Front Screen Assembly Replacement: adım 4, 1 resimden 1.
    • Use the plastic opening tool to push up on the wire to remove it completely.
  5. ZTE Tempo Front Screen Assembly Replacement: adım 5, 2 resimden 1. ZTE Tempo Front Screen Assembly Replacement: adım 5, 2 resimden 2.
    • Insert and slide the plastic opening tool alongside the seam, gently wiggling the opening tool to open and remove the motherboard.
  6. ZTE Tempo Front Screen Assembly Replacement: adım 6, 3 resimden 1. ZTE Tempo Front Screen Assembly Replacement: adım 6, 3 resimden 2. ZTE Tempo Front Screen Assembly Replacement: adım 6, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Use the metal spudger to push up to remove the volume control.
    • Use the tweezers to remove the front speaker and bottom controller.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
omar
717 İtibar
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 9
Her zaman: 307
