Ana içeriğe geç
ZTE Tempo Front Speaker Replacement
Neye ihtiyacın var
  1. ZTE Tempo Front Speaker Replacement, Battery: adım 1, 2 resimden 1. ZTE Tempo Front Speaker Replacement, Battery: adım 1, 2 resimden 2.
    • Use a plastic opening tool to pry open the back case.
    • Use a Phillips #0 screwdriver to remove the eight 5mm screws.
    • Use a plastic opening tool to remove the midframe.
  2. ZTE Tempo Front Speaker Replacement: adım 2, 3 resimden 1. ZTE Tempo Front Speaker Replacement: adım 2, 3 resimden 2. ZTE Tempo Front Speaker Replacement: adım 2, 3 resimden 3.
    • Use a plastic opening tool to lift the press-fit connector up and disconnect the battery ribbon cable.
    • Lift the battery up and remove it from the phone.
  3. ZTE Tempo Front Speaker Replacement, Front Speaker: adım 3, 3 resimden 1. ZTE Tempo Front Speaker Replacement, Front Speaker: adım 3, 3 resimden 2. ZTE Tempo Front Speaker Replacement, Front Speaker: adım 3, 3 resimden 3.
    • Use a plastic opening tool to unplug the wires by pulling them to the side.
  4. ZTE Tempo Front Speaker Replacement: adım 4, 2 resimden 1. ZTE Tempo Front Speaker Replacement: adım 4, 2 resimden 2.
    • Use metal tweezers to remove the front speaker.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
omar
717 İtibar
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 155
