Ana içeriğe geç
ZTE Tempo Rear Camera Replacement
Neye ihtiyacın var
  1. ZTE Tempo Rear Camera Replacement, Rear Camera: adım 1, 2 resimden 1. ZTE Tempo Rear Camera Replacement, Rear Camera: adım 1, 2 resimden 2.
    • Pry open the back case to get to the back cover.
    • Remove eight 5mm screws with a PH0 screw.
    • Pry open the back cover with a plastic opening tool.
    • Slide the plastic opening tool alongside the side seam twisting your hand forcefully to open the back cover.
    • Note: Pry open by finding an edge and forcing it open with the plastic opening tool.
  2. ZTE Tempo Rear Camera Replacement: adım 2, 2 resimden 1. ZTE Tempo Rear Camera Replacement: adım 2, 2 resimden 2.
    • Use a plastic opening tool to lift the press-fit connector up and disconnect the battery ribbon cable.
  3. ZTE Tempo Rear Camera Replacement: adım 3, 2 resimden 1. ZTE Tempo Rear Camera Replacement: adım 3, 2 resimden 2.
    • Use a plastic opening tool to lift the press-fit connector up and disconnect the rear camera ribbon cable.
    • Lift the rear camera out of the phone.
Sonuç
Bir başkası bu kılavuzu tamamladı.
omar
717 İtibar
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 10
Her zaman: 153
