Ana içeriğe geç
ZTE Tempo X Charging/Aux Board Replacement
Neye ihtiyacın var
  1. ZTE Tempo X Charging/Aux Board Replacement, Back Cover: adım 1, 2 resimden 1. ZTE Tempo X Charging/Aux Board Replacement, Back Cover: adım 1, 2 resimden 2.
    • Remove back cover using the divot provided.
  2. ZTE Tempo X Charging/Aux Board Replacement, Battery: adım 2, 2 resimden 1. ZTE Tempo X Charging/Aux Board Replacement, Battery: adım 2, 2 resimden 2.
    • Find the divot near the bottom of the battery and remove the battery from the device.
  3. ZTE Tempo X Charging/Aux Board Replacement, Charging/Aux Board: adım 3, 2 resimden 1. ZTE Tempo X Charging/Aux Board Replacement, Charging/Aux Board: adım 3, 2 resimden 2.
    • Remove the sixteen 3mm screws using the Phillips #000 screwdriver.
  4. ZTE Tempo X Charging/Aux Board Replacement: adım 4, 2 resimden 1. ZTE Tempo X Charging/Aux Board Replacement: adım 4, 2 resimden 2.
    • Take off the second back cover, lifting from the bottom of the device to the top.
  5. ZTE Tempo X Charging/Aux Board Replacement: adım 5, 3 resimden 1. ZTE Tempo X Charging/Aux Board Replacement: adım 5, 3 resimden 2. ZTE Tempo X Charging/Aux Board Replacement: adım 5, 3 resimden 3.
    • Using a spudger, unclip the board from the phone at the places highlighted.
  6. ZTE Tempo X Charging/Aux Board Replacement: adım 6, 3 resimden 1. ZTE Tempo X Charging/Aux Board Replacement: adım 6, 3 resimden 2. ZTE Tempo X Charging/Aux Board Replacement: adım 6, 3 resimden 3.
    • Use the spudger to remove the board from the phone.
    • The board is held by glue so there will be resistance when detaching it from the phone.
Sonuç
Conager Robb
592 İtibar
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 11
Her zaman: 244
