Ana içeriğe geç
ZTE Whirl 2 Camera Replacement
Neye ihtiyacın var
  1. ZTE Whirl 2 Camera Replacement, Battery: adım 1, 3 resimden 1. ZTE Whirl 2 Camera Replacement, Battery: adım 1, 3 resimden 2. ZTE Whirl 2 Camera Replacement, Battery: adım 1, 3 resimden 3.
    • Power off your phone before removing the battery.
    • Pry the cover off the back of the phone using your fingers.
    FixBot'a Sor
    Yorum Ekle
  2. ZTE Whirl 2 Camera Replacement: adım 2, 3 resimden 1. ZTE Whirl 2 Camera Replacement: adım 2, 3 resimden 2. ZTE Whirl 2 Camera Replacement: adım 2, 3 resimden 3.
    • Pry the battery from the phone using your fingers.
    FixBot'a Sor
    Yorum Ekle
  3. ZTE Whirl 2 Camera Replacement, Back Panel: adım 3, 3 resimden 1. ZTE Whirl 2 Camera Replacement, Back Panel: adım 3, 3 resimden 2. ZTE Whirl 2 Camera Replacement, Back Panel: adım 3, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Remove four 4 mm screws using a Phillips #00 screwdriver.
    • Use a tweezers to remove the lock sticker from the bottom right screw. Remove the 4 mm screw using a Phillips #00 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  4. ZTE Whirl 2 Camera Replacement: adım 4, 3 resimden 1. ZTE Whirl 2 Camera Replacement: adım 4, 3 resimden 2. ZTE Whirl 2 Camera Replacement: adım 4, 3 resimden 3.
    • Insert an opening pick between the midframe and the digitizer.
    • Move the pick around the midframe to detach the midframe from the digitizer.
    • The lock button and volume buttons may fall out during this process.
    FixBot'a Sor
    Yorum Ekle
  5. ZTE Whirl 2 Camera Replacement: adım 5, 1 resimden 1.
    • Remove the midframe from the digitizer.
    FixBot'a Sor
    Yorum Ekle
  6. ZTE Whirl 2 Camera Replacement, Camera: adım 6, 3 resimden 1. ZTE Whirl 2 Camera Replacement, Camera: adım 6, 3 resimden 2. ZTE Whirl 2 Camera Replacement, Camera: adım 6, 3 resimden 3.
    • Use the iFixit Opening Tool to disconnect the camera connector by prying up the press fit connector from the motherboard.
    • Remove the camera from the device.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Alana
461 İtibar
4 adet Kılavuz yazıldı
Ekip
UW Stout, Team S1-G1, Schneider-Bateman Spring 2020 UW Stout, Team S1-G1, Schneider-Bateman Spring 2020 üyesi
UWSTOUT-SCHNEIDER-BATEMAN-S20S1G1
3 Üyeler
15 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 28
Her zaman: 334
