Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Giriş
If your ZTE Whirl 2 (model Z667G) isn’t producing clear audio from the primary speaker, use this guide to replace the speaker.
The speaker for the phone is the main function that is used during calls and when a ringtone sounds. A faulty phone speaker can result in little audio to none at all.
Before using this guide, inspect the speaker area for any debris that may be interfering with the sound quality.
Before beginning, make sure your phone is off and is disconnected from any power source.
  1. Power off your phone before removing the battery. Pry the cover off the back of the phone using your fingers. Pry the cover off the back of the phone using your fingers.
    • Power off your phone before removing the battery.
    • Pry the cover off the back of the phone using your fingers.
  2. Pry the battery from the phone using your fingers. Pry the battery from the phone using your fingers. Pry the battery from the phone using your fingers.
    • Pry the battery from the phone using your fingers.
  3. Remove four 4 mm screws using a Phillips #00 screwdriver. Use a tweezers to remove the lock sticker from the bottom right screw. Remove the 4 mm screw using a Phillips #00 screwdriver. Use a tweezers to remove the lock sticker from the bottom right screw. Remove the 4 mm screw using a Phillips #00 screwdriver.
    • Remove four 4 mm screws using a Phillips #00 screwdriver.
    • Use a tweezers to remove the lock sticker from the bottom right screw. Remove the 4 mm screw using a Phillips #00 screwdriver.
  4. Insert an opening pick between the midframe and the digitizer. Move the pick around the midframe to detach the midframe from the digitizer. The lock button and volume buttons may fall out during this process.
    • Insert an opening pick between the midframe and the digitizer.
    • Move the pick around the midframe to detach the midframe from the digitizer.
    • The lock button and volume buttons may fall out during this process.
  5. Remove the midframe from the digitizer.
    • Remove the midframe from the digitizer.
  6. Use tweezers to remove the lock button and volume stickers from the phone. The volume buttons peel off much like a sticker.
    • Use tweezers to remove the lock button and volume stickers from the phone.
    • The volume buttons peel off much like a sticker.
  7. Use a tweezers to lift the lock from the ZIF connector above the camera. Pull the ribbon from the connector.
    • Use a tweezers to lift the lock from the ZIF connector above the camera. Pull the ribbon from the connector.
    • The ribbon is connected by a lock. Flip the lock up to unlatch the ribbon with a set of tweezers.
  8. Use a tweezers to lift the lock from the ZIF connector. Pull the ribbon from the connector. Like the camera ribbon, it has a latch that you need to flip to unlock.
    • Use a tweezers to lift the lock from the ZIF connector. Pull the ribbon from the connector.
    • Like the camera ribbon, it has a latch that you need to flip to unlock.
  9. Pull the speaker from the phone by using a pair of tweezers.
    • Pull the speaker from the phone by using a pair of tweezers.
    • The speaker has a sticky like back, it peels easiest with a tweezers.
Sonuç
Alana Rucks
461 İtibar
4 adet Kılavuz yazıldı
Takım
UW Stout, Team S1-G1, Schneider-Bateman Spring 2020 UW Stout, Team S1-G1, Schneider-Bateman Spring 2020 üyesi
UWSTOUT-SCHNEIDER-BATEMAN-S20S1G1
3 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 30
