Ana içeriğe geç
Giriş
This guide shows how to replace the speaker for ZTE Z667T.
  1. Gently insert your fingernail into the bottom left crevice of the back cover and lift up.
    • Gently insert your fingernail into the bottom left crevice of the back cover and lift up.
  2. Remove the battery by inserting your fingernail at the top of the battery and lift up.
    • Remove the battery by inserting your fingernail at the top of the battery and lift up.
  3. Using a Phillips #000 screwdriver, remove the five screws located on the back case.
    • Using a Phillips #000 screwdriver, remove the five screws located on the back case.
  4. Gently pry open the back case using the plastic opening tool.
    • Gently pry open the back case using the plastic opening tool.
    • Pry open in multiple locations to avoid damage.
  5. Using the plastic opening tool, gently lift the speaker out of the back case.
    • Using the plastic opening tool, gently lift the speaker out of the back case.
Sonuç
Michael Lidbetter
121 İtibar
1 Kılavuz yazıldı
Takım
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 0
Her zaman: 76
