Ana içeriğe geç
ZTE ZFive G LTE Front-Facing Camera Replacement
Neye ihtiyacın var
    1. ZTE ZFive G LTE Front-Facing Camera  Replacement, Front-Facing Camera: adım 1, 3 resimden 1. ZTE ZFive G LTE Front-Facing Camera  Replacement, Front-Facing Camera: adım 1, 3 resimden 2. ZTE ZFive G LTE Front-Facing Camera  Replacement, Front-Facing Camera: adım 1, 3 resimden 3.
      • Using the opening tool, pry open the rear cover from the crease at the bottom left corner.
      FixBot'a Sor
      Yorum Ekle
    2. ZTE ZFive G LTE Front-Facing Camera  Replacement: adım 2, 3 resimden 1. ZTE ZFive G LTE Front-Facing Camera  Replacement: adım 2, 3 resimden 2. ZTE ZFive G LTE Front-Facing Camera  Replacement: adım 2, 3 resimden 3.
      • Remove the battery with an opening tool or fingernail.
      FixBot'a Sor
      Yorum Ekle
    3. ZTE ZFive G LTE Front-Facing Camera  Replacement: adım 3, 1 resimden 1.
      • Unscrew all 16 screws from the mid-frame J000 screwdriver.
      • Set the screws aside.
      FixBot'a Sor
      Yorum Ekle
    4. ZTE ZFive G LTE Front-Facing Camera  Replacement: adım 4, 2 resimden 1. ZTE ZFive G LTE Front-Facing Camera  Replacement: adım 4, 2 resimden 2.
      • Gently pull up the device body from the inside.
      • Make sure to pull on all four sides as shown here.
      FixBot'a Sor
      Yorum Ekle
    5. ZTE ZFive G LTE Front-Facing Camera  Replacement: adım 5, 2 resimden 1. ZTE ZFive G LTE Front-Facing Camera  Replacement: adım 5, 2 resimden 2.
      • Once the body is removed, you will see the front facing camera at the top right corner of the device.
      • Using an opening tool, lift up the protective clip on top of the camera's ribbon wire.
      FixBot'a Sor
      Yorum Ekle
    6. ZTE ZFive G LTE Front-Facing Camera  Replacement: adım 6, 2 resimden 1. ZTE ZFive G LTE Front-Facing Camera  Replacement: adım 6, 2 resimden 2.
      Bu adımda kullanılan alet:
      $3.99
      • Using angled tweezers, gently pull the ribbon wire up from the body.
      • With the ribbon wire out, you should be able to remove the camera.
      • If there is adhesive on the camera backing, it may require more force to pull the camera out.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 9
Son 30 gün: 33
Her zaman: 706
