Ana içeriğe geç
ZTE ZFive G LTE Front-Facing Camera Replacement
Neye ihtiyacın var
  1. ZTE ZFive G LTE Front-Facing Camera  Replacement, Front-Facing Camera: adım 1, 3 resimden 1. ZTE ZFive G LTE Front-Facing Camera  Replacement, Front-Facing Camera: adım 1, 3 resimden 2. ZTE ZFive G LTE Front-Facing Camera  Replacement, Front-Facing Camera: adım 1, 3 resimden 3.
    • Using the opening tool, pry open the rear cover from the crease at the bottom left corner.
  2. ZTE ZFive G LTE Front-Facing Camera  Replacement: adım 2, 3 resimden 1. ZTE ZFive G LTE Front-Facing Camera  Replacement: adım 2, 3 resimden 2. ZTE ZFive G LTE Front-Facing Camera  Replacement: adım 2, 3 resimden 3.
    • Remove the battery with an opening tool or fingernail.
  3. ZTE ZFive G LTE Front-Facing Camera  Replacement: adım 3, 1 resimden 1.
    • Unscrew all 16 screws from the mid-frame J000 screwdriver.
    • Set the screws aside.
  4. ZTE ZFive G LTE Front-Facing Camera  Replacement: adım 4, 2 resimden 1. ZTE ZFive G LTE Front-Facing Camera  Replacement: adım 4, 2 resimden 2.
    • Gently pull up the device body from the inside.
    • Make sure to pull on all four sides as shown here.
  5. ZTE ZFive G LTE Front-Facing Camera  Replacement: adım 5, 2 resimden 1. ZTE ZFive G LTE Front-Facing Camera  Replacement: adım 5, 2 resimden 2.
    • Once the body is removed, you will see the front facing camera at the top right corner of the device.
    • Using an opening tool, lift up the protective clip on top of the camera's ribbon wire.
  6. ZTE ZFive G LTE Front-Facing Camera  Replacement: adım 6, 2 resimden 1. ZTE ZFive G LTE Front-Facing Camera  Replacement: adım 6, 2 resimden 2.
    • Using angled tweezers, gently pull the ribbon wire up from the body.
    • With the ribbon wire out, you should be able to remove the camera.
    • If there is adhesive on the camera backing, it may require more force to pull the camera out.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 340
