Ana içeriğe geç
ZTE ZFive G LTE Volume and Power Button Replacement
Neye ihtiyacın var
  1. ZTE ZFive G LTE Volume and Power Button Replacement, Volume and power button: adım 1, 3 resimden 1. ZTE ZFive G LTE Volume and Power Button Replacement, Volume and power button: adım 1, 3 resimden 2. ZTE ZFive G LTE Volume and Power Button Replacement, Volume and power button: adım 1, 3 resimden 3.
    • Remove back cover of the device from the crease of the bottom left corner using opening tool or fingernail.
  2. ZTE ZFive G LTE Volume and Power Button Replacement: adım 2, 2 resimden 1. ZTE ZFive G LTE Volume and Power Button Replacement: adım 2, 2 resimden 2.
    • Remove the battery with an opening tool or fingernail.
  3. ZTE ZFive G LTE Volume and Power Button Replacement: adım 3, 2 resimden 1. ZTE ZFive G LTE Volume and Power Button Replacement: adım 3, 2 resimden 2.
    • Unscrew all 16 screws from the mid-frame with a J000 screwdriver.
  4. ZTE ZFive G LTE Volume and Power Button Replacement: adım 4, 2 resimden 1. ZTE ZFive G LTE Volume and Power Button Replacement: adım 4, 2 resimden 2.
    • Being careful with the device, gently pull up the device body tugging from the inside of the device.
    • Be sure to pull away from the device.
  5. ZTE ZFive G LTE Volume and Power Button Replacement: adım 5, 2 resimden 1. ZTE ZFive G LTE Volume and Power Button Replacement: adım 5, 2 resimden 2.
    • Carefully use a pair of bent nose tweezers to pull out the button cover. I should come out easily.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 4
Her zaman: 315
